Sponsored by: Real Truck
High Idle Switch
Old Aug 25, 2002 | 09:46 PM
jchartkoff's Avatar
jchartkoff
Post High Idle Switch
Can anybody tell me if there is a good way to to add a high idle switch to an F250 with a V10? The problem is that the alternator while at idle will not keep up with th emergency lighting equipment, and runs the battery down to the point where the engine dies after about an hour.
There is such a factory option for the PSD but I can not find info on the gas versions.
Any help would be most appreciated.
Old Aug 25, 2002 | 10:14 PM
FortyFords's Avatar
FortyFords
High Idle Switch
Haven't seen any for gassers! maybe you need a high amp altenator.
or a pulley change to your altenator.
or a dual battery setup.
I thought www.Mechman.com had upgrades for our altenators.
Sorry I couldn't help any further.
Rich
Old Aug 26, 2002 | 01:56 PM
DougB442's Avatar
DougB442
High Idle Switch
The PSD idle switch is supposed to work on the gas engines as well. Supposedly it connects to the harness in the same location and everything.
Old Aug 26, 2002 | 03:37 PM
NoMo's Avatar
NoMo
High Idle Switch
http://www.vmac.ca/throttle/new_products.htm
Old Aug 26, 2002 | 03:56 PM
NoMo's Avatar
NoMo
High Idle Switch
farnorthdan
6.4L Power Stroke Diesel
90
Jul 3, 2019 09:14 AM
Number21
Nov 18, 2013 12:27 PM
FUJINAMI1293
Jul 17, 2012 06:37 AM
Schmagma
6.7L Power Stroke Diesel
Aug 4, 2010 09:14 PM
savage250
Apr 16, 2007 12:11 AM
