High Idle Switch
Old Apr 15, 2007 | 03:56 PM
savage250's Avatar
savage250
High Idle Switch
can you set up a switch that runs the truck up to 1000 or 1200 rpm on a '03 7.3?
Old Apr 15, 2007 | 09:44 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I think so. I know you can on the pre-01 trucks with the seperate IVS and TPS, and the wiring is the same on the later trucks, so it should work without issue.
Can't find the link I used to have for that, so I'll have to look at the truck to remember what goes where.
Old Apr 15, 2007 | 09:47 PM
Uzumati's Avatar
Uzumati
https://www.ford-trucks.com/forums/5...e-control.html
Double check the wiring colors before splicing.
Old Apr 16, 2007 | 12:11 AM
fixnair's Avatar
fixnair
I am in the process of doing that now. I have used two relays, a switch and a reostat to adjust the speed desired. The two relays are operated one by the E-Brake and the other by the switch which is installed in the dash. So you have to be stopped and have the E-Brake applied for it to work. I have not gotten the correct value on the reostat yet. The one I chose is a 0-5K ohm. I am finding that is not suitable. At its lowest setting the engine runs @ 1600 RPM. Just the slightest increase in reostat and the engine pegs the tach. I am going to try a 0-10K ohm reostat next week. I found the instructions for this on this site but do not have the source available right now. If you do a search on this subject you'll probably find it.
Niwrek
Feb 15, 2016 11:26 PM
alexisvfd
Nov 19, 2015 10:55 PM
abyars111
Apr 10, 2015 02:34 PM
narrowfarm
Oct 16, 2014 09:22 PM
ExtrmZ
Oct 7, 2014 07:33 AM
