High Idle switch
Old Jul 17, 2012 | 01:38 AM
FUJINAMI1293's Avatar
FUJINAMI1293
High Idle switch
Is it possible to install a High Idle switch on a 2001 F350 7.3?
If it is does anybody has instructions?
Old Jul 17, 2012 | 02:16 AM
BigAlsPSD's Avatar
BigAlsPSD
There can be a few options, an Auxiliary Idle Controller(Can be pricey)
If your trans is a PTO, and for some reason even some non PTO it might be worth a shot to try, pretty cheap if it doesn't. You simply apply 12v to pin 66 of the PCM here is a post on that PTO transmission high idle
Or the most common aside from tuning is a setup similar to this thread
Cookie's Home Brew High Idle or this one Home Brew High Idle
Old Jul 17, 2012 | 05:08 AM
Firefighter 1406's Avatar
Firefighter 1406
Big al hit in on the head. My e99 the homemade way would not work. But after a lot of searching and help from my FTE brothers I did find a aux idle control wih wiring and mount for $100 on Craigslist.
Old Jul 17, 2012 | 06:37 AM
Tugly's Avatar
Tugly
If you ever get to the point of chipping, there are hi-idle programs taylored to your needs. I live way up North and I sometimes need a warm-up idle. My tuner bumps the idle RPM up and closes the Exhaust Back Pressure Valve to speed the warmup time on those crazy-cold mornings, and I use it for giving other vehicles a jump. Chipping is a big expense, so it's not for everybody.
SARDiverDan
Sep 30, 2012 05:24 PM
levimorris85
129
May 15, 2012 03:58 PM
dieseltruck02
22
Dec 13, 2007 11:03 PM
Squiggy
Nov 25, 2007 07:42 PM
kenny_barg
Mar 20, 2007 10:52 PM
