2004 High idle switch location?
Old Nov 7, 2013 | 03:45 AM
Number21's Avatar
Number21
I'm planning on hooking up the high idle switch in my 2004 6.0. I understand that I need to put a switch in the wires that are already behind the dash. What I'm wondering is where did Ford hook these wires? Is there a factory high idle switch I can buy? From what I can tell, 2003-2004 is different than the switches used in 2005 and up. (and so is the way the high idle works)
Old Nov 7, 2013 | 10:38 AM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
Old Nov 7, 2013 | 11:08 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Here is where I put mine. I found the switches on a counter display at my local auto-parts store. You can also find a good selection at
Switches || Keep It Clean Wiring
My 4 switches are from left to right: DVD, reverse lights, heated mirrors, high idle.
If you want to put them in where I did, you need to make sure you feel the underside of the plastic, there are some vertical moldings on the back side.
Old Nov 7, 2013 | 04:01 PM
Number21's Avatar
Number21
Why? This is a generic Super Duty question. Gassers have high idle as well.
That does look nice, I'll probably need a few other switches as well.
Still curious where Ford put the switch? Or was this only an option the chassis builders use?
Old Nov 7, 2013 | 04:20 PM
powerstroke72
Because you've got a 6.0 and rarely, if ever, does anyone post about the high idle on a gas Super Duty in the SD forum. They do post a lot about it on the 6.0L forum though. Even better....there's a little box at the top of the page that allows you to search the forums for answers. It may have saved you some time and answered your question.
Old Nov 7, 2013 | 04:24 PM
Number21's Avatar
Number21
Still a generic Super Duty question, and yes I searched. There are high idle questions all over the Super Duty forum...
Old Nov 7, 2013 | 04:35 PM
powerstroke72
Well, either way, you should get an answer.
Old Nov 7, 2013 | 04:38 PM
Misky6.0's Avatar
Misky6.0
FORD doesn't install a switch for high-idle.
Typically, the chassis would be sent to an aftermarket company to add the motor home body, tow truck body, cargo van, etc. and that company would install their own console with whatever switches they wanted.
You "could" wire it to the e-brake sensor and NOT need a switch - but whenever you put on the e-brake (while in park) the high-idle would kick-in.
Lots of folks also use an upfitter switch to wire it to - if they want and have them.
Old Nov 7, 2013 | 04:49 PM
npccpartsman's Avatar
npccpartsman
It's as easy as this:
Old Nov 7, 2013 | 04:56 PM
Number21's Avatar
Number21
Yeah, I saw that video. Just curious if there was an official switch...I used to have a Jeep with a fancy factory "extended idle" switch.
Is there any possibility of controlling the high idle speed on an 04, or is that only for 05 and up?
Old Nov 7, 2013 | 05:04 PM
npccpartsman
What do you mean controlling? Raising and lowering the RPM's manually say to 800, 900, or 1000??? No.....
AFA official switches, you can get the upfitter panel and switches if you want it to look factory, but no there isn't an official factory switch for an 04 that I'm aware of.
Old Nov 7, 2013 | 06:55 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
There are 2 different options for 05+ high idles, PTO or Battery Charge.
PTO is a fixed RPM of about 1200, the BCP is a variable High RPM according to demand.
Josh
Old Nov 7, 2013 | 07:23 PM
big inch's Avatar
big inch
I wired mine to the parking brake switch. It works fine.
Old Nov 8, 2013 | 09:57 AM
RKCORPS25's Avatar
RKCORPS25
Just curious could you flip the switch right after turning the truck on in the cold morning
Old Nov 8, 2013 | 10:02 AM
npccpartsman
That's what it's for. Makes the truck high idle to help warm the engine faster, prevent wet stacking, and EGR issues. As soon as you hit the brake pedal it idles down, even with the switch actuated.
