Sponsored by: Real Truck
4wd sof actuator?
Old Jan 7, 2004 | 10:17 AM
Tipi's Avatar
Tipi
4wd sof actuator?
Hi All, Have a 99 F250SD with auto hubs that do not work. Must manualy engage them. Understand there is a vacuum line that does this when in auto mode. Where does it run to and from so i can see if there is a leak. My service station guy says it is done with centrifical force not vacuum. Any help?
Thanks
Tipi
Old Jan 7, 2004 | 02:29 PM
Big Orn's Avatar
Big Orn
Welcome to FTE!
The front hubs lock via vacuum. The lines run from each hub and into the engine compartment. On your '99 you can see the connections close to your battery where you can follow them from there.
Remember that the engine must be running and the ESOF switch engaged to pull vacuum, so you may need a partner to help you.
Good luck.
PS - have you worked the hubs to make sure they're not stuck?
Old Jan 7, 2004 | 02:44 PM
e8411a's Avatar
e8411a
Thumbs up
I have the same problem, check these threads because lots of others have had the problem to.
https://www.ford-trucks.com/forums/s...252B%25252Bhubs
or: https://www.ford-trucks.com/forums/s...252B%25252Bhubs
scarty111
Aug 14, 2013 03:43 PM
clearwater1950
Jan 20, 2012 02:10 AM
66gpw
Oct 24, 2011 09:37 PM
AutoAppearancesInc
Aerostar
May 7, 2009 09:35 PM
