1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Need engine compartment drawing of vacuum system.
Old 01-20-2012, 12:30 AM
clearwater1950's Avatar
clearwater1950
clearwater1950 is offline
My 99 250 Diesel heater system intermittently defaults to the defrost position. Also, my 4-WD switch is now intermittently activating the auto hubs (they work on manual). I have read many helpful posts on the heater problem and have checked all the underdash vacuum lines and connections that I can find (for the heater system). They all look good. I am not sure what too look for in the engine compartment. Does anyone have a good picture/diagram of the under hood layout of the vacuum system? and....What creates vacuum and where is it located? Does the same vacuum system create vacuum for the 4WD switch and heater system? thanks.
Old 01-20-2012, 02:10 AM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
The same system feeds hvac and 4x4 controls. Usually when it acts as yours does, it is the either and internal hub seal or the actual vacuum line that feeds each front hub has rotted. You can look on the back of the hub and trace the line up.
That thread there deals with your same issue.
https://www.ford-trucks.com/forums/5...ped-workn.html
tommy curtiss
10-29-2017 06:14 PM
Galendor
27
05-29-2016 10:11 PM
Walleye Hunter
04-03-2014 05:05 PM
1997fordf350
01-15-2013 06:59 PM
Quick Reply: Need engine compartment drawing of vacuum system.
