Sponsored by: Real Truck
code flash?
Old Aug 25, 2002 | 06:31 AM
scraprat's Avatar
scraprat
Top Answer: 5
code flash?
The airbag light on the dash has been flash a code 27 for some time, as soon as I start the truck, some times not till the truck has been running for awhile(10-30miles).I had a speed sensor problem but i replaced it(rear axel), Then i took it to the ford dealership to see about this flashing code. They put it on the computer which said everyting checked out and cleared the code. A day later it starts again. I'm always away from home working putting about on about 1000-1500 miles aweek on the truck. And that light is starting to worry me.I can't notice anything wrong. Any help would sure help. Thanks. The truck is a 99 250sd 5.4 auto.128,000 miles.
Old Sep 26, 2002 | 10:00 PM
bandit99's Avatar
bandit99
code flash?
[updated:LAST EDITED ON 26-Sep-02 AT 11:13 PM (EST)]Mine is doing the same thing. I've also noticed the light on the dash by the on/off switch for the passenger side is inoperative. Anybody else having probs? I've read in other posts that you have to solder a bulb onto the circuit board for the disabling the bag? Has anybody else done this? thanks in advance Trey
Old Sep 27, 2002 | 04:35 AM
FortyFords's Avatar
FortyFords
code flash?
Does the lamp flash a couple of times ,then stay on?
if so this indicates a hard fault within the system! must be repaired by the dealer.
These are tricky to find without the use of the dealer computer.
Does your seat belt warning chime still work? if no go back to the dealer,there is a RCM module that controls the airbags system
I don't know your dealer reputation ,but with the way some dealers are they like to get you coming back in for repeat service this is where they make there $
If when they know they can reset the fault and wait for it to surface again
just my $.02
Rich
Old Sep 27, 2002 | 05:26 AM
bandit99's Avatar
bandit99
code flash?
Thanks, I'll check the warning chime, I don't remember it working.
Old Sep 28, 2002 | 05:10 AM
scraprat's Avatar
scraprat
Top Answer: 5
code flash?
Rich, the seat belt chime doesn,t work. So I asume that the air bags just won,t work. The code flash has nothing to do with the engine it self?
Old Sep 28, 2002 | 06:17 AM
slammer's Avatar
slammer
code flash?
tomanycars
Jul 15, 2010 10:27 PM
trapperack
Dec 24, 2009 04:35 PM
trapperack
2009 - 2014 F150
Dec 22, 2009 04:57 PM
wrdabney
Dec 27, 2008 09:06 AM
bdraft
May 13, 2007 07:27 PM
