400 Mercury??
Old Jan 3, 2004 | 11:39 AM
F100_1964's Avatar
F100_1964
400 Mercury??
Will a 400 Mercury bolt in the place of the 351m in my 1981 Bronco? I know the 400 Ford will, but will a Mercury? Thanks in advance.
Old Jan 3, 2004 | 12:28 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Never heard of a 400 mercury...
Old Jan 3, 2004 | 12:43 PM
scroob's Avatar
scroob
Yes.
Old Jan 3, 2004 | 12:55 PM
51F3's Avatar
51F3
Yes, From what I know. 351M & 400 are the same block, just different bores(?) and or strokes(?)
What is the Mercury engine out of, or do you know? year? I have seen some people call an engine a 400 when actually it was an old 410. But for no other reason than that, they weren't sure of the cu. in. and engine family.
Old Jan 3, 2004 | 03:05 PM
c_rossman's Avatar
c_rossman
Only difference is the crank, rods, pistons. Block and heads are the same i believe.
Old Jan 3, 2004 | 06:32 PM
F100_1964's Avatar
F100_1964
It is out of a Mercury Monterey. The year, I don't know. The engine looks just like a 351M/400 Ford. It says 400-2V on the Air Cleaner housing. I know nothing about the car except that it took a major impact on the passenger side. My mom had a '73 Mercury Montego with a 400. I know the firing order is different than the Ford. My dad tuned it up one time and tried to put the plug wires back on like a 400 Ford and it wouldn't hardly run, looked up in the Chilton, saw the Mercury section, fixed the wires, problem solved. Thanks for all your help.
Old Jan 3, 2004 | 10:43 PM
bubbaf250's Avatar
bubbaf250
Any 351M/400 engine will bolt in place of any other 351M/400 engine, except for a somewhat rare 1973 400 variant that used the small-block (302/351W/351C) bell housing pattern. Other than its bell housing mount, even that 400 will bolt in place of any other 400 (same engine block mounts).
All 351M/400 engines have the same firing order (which is the same as the 351C firing order). It's possible your dad tried to use the 302/351W firing order, or the 460 firing order, which is different.
The only functional components that are different in 351M and 400 engines are the crankshafts and pistons. Both engines use the same connecting rods (with a taller piston in the 351M to make up the stroke difference).
Check this page for more general info about the 351M/400 engines:
http://home.earthlink.net/~bubbaf250/
Check this page for a list of Ford and Lincoln/Mercury vehicles that were equipped with the 351M/400 engines:
http://home.earthlink.net/~bubbaf250...history10.html
Old Jan 4, 2004 | 11:46 AM
scroob's Avatar
scroob
Why in the world would the firing order be different between a 400 Ford and Mercury? By '73, the only difference between the 2 makes were cosmetic.
Far more likely your mom had some other engine and someone stuck a 400 air cleaner on it.
Old Jan 8, 2004 | 07:35 PM
califasbob's Avatar
califasbob
There were 400's installed in some Mercurys, being a rookie at this I learned it the hard way! I pulled a 400 out of a junk 74 Cougar (foolishly believing it was a Cleveland) for my rebuild. Nowhere on the motor did the word Mercury appear, in fact it had the Power by Ford stock valvecovers. It was bolted to a big block pattern C-6, just like the one behind the 351M in my 78 F-150.
The firing order question seems hard to believe...
Good luck on the Bronco!
Robert Booth
'78 Ford F-150 Explorer
Arlington, TX
46yblock
33
Aug 19, 2017 07:26 PM
429unibody
20
Nov 14, 2009 09:23 AM
Snowking
31
Oct 12, 2007 08:19 AM
Ford51
Flathead V8 & Flathead 6
Feb 20, 2006 10:37 PM
bememe
Jul 1, 2002 09:09 AM
