Flashes defined! What each one does...
Old Jan 5, 2004 | 05:46 AM
  #31
SBV45's Avatar
SBV45
Found another good reference page http://www.intellidog.com/dieselmann/home.html There is a bulletins section for the 6.0 that is pretty comprehensive. Some of the stuff is for the 7.3 only.
Old Jan 5, 2004 | 10:29 AM
  #32
Jontx's Avatar
Jontx
emtabmm:
some of the stuff from Ford mentioned tip in and tip out. What does that mean???
Jon
Old Jan 5, 2004 | 02:37 PM
  #33
jetguy's Avatar
jetguy
I have a 2003 and I have had no problems with bad injectors and the truck runs ok right now . It does idle a little rough sometimes and the fuel mielage could be a little better. The only bad thing that it has done is quit twice when stopping at stop sign but it starts right away. I am not sure what reflash it has but it goes in tomorrow for an oil change so mabey I should get it reflashed. Any help would be appreciated my sn is 1FTSW31P83EC10583. thanks.
Old Jan 5, 2004 | 04:53 PM
  #34
emtabmm's Avatar
emtabmm
Originally posted by Jontx
emtabmm:
Jon
"tip in" is when you are just starting to depress the accel to take off....
"tip out" is when you first let your foot off the throttle....
Old Jan 6, 2004 | 05:03 AM
  #35
flounder's Avatar
flounder
I have read that several people that have recently had their trucks reflashed have experienced increase idle speed with start up. I recently had my truck reflashed a week ago and this holds true with mine. Question I have is that is this the December reflash and part of the fix? No problem with it, just wondering.
Also where does the reflash ID # appear? On the paper work or under the hood on the reflash sticker. Thanks.
Old Jan 6, 2004 | 05:32 AM
  #36
emtabmm's Avatar
emtabmm
Higher idle is part of the flash to compensate for lack of pilot injection, # should be on sticker under hood.
Old Jan 6, 2004 | 05:58 AM
  #37
flounder's Avatar
flounder
Thats what I figured. Been kind of keeping eye on changes/differences pre and post flash to report and compare to you guys.
Also noticed pronounced hum in turbo on 2 starts yesterday but not this am. That was kind of weird first time noise. Hope thats not another glitch waiting to rear it ugly head. Thanks for your response back!
Old Jan 6, 2004 | 07:24 AM
  #38
psdwanabe's Avatar
psdwanabe
Actually the higher idle came about on the Aug reflash. It was to help with the poor performing AC at idle. Many people complained it was a poor attempt at a fix that didn't work. And like all reflashes, the Aug reflash is part of the Dec reflash so your idle will increase.
Old Jan 6, 2004 | 07:58 AM
  #39
flounder's Avatar
flounder
yes i noticed on emtabmm's list on reflashes how accumlative they are from the first one. Also wondered how reflashes affect the injector issue or if they affect them at all. I have heard some say it was fords attempt to extend their life past warranty but I dont see how it could do it. thanks.
Old Jan 6, 2004 | 08:15 AM
  #40
psdwanabe's Avatar
psdwanabe
Yes the extended life of an injector does make sense. But I don't think that was Fords purpose, I think it was a side benefit. I believe the purpose of pilot deactivation was the inability of the 6.0 to run smoothly at idle. And how long would it actually extend the life of the injector? Its only used at idle, what percentage of time does it sit at idle? I don't think the extended longevity would be significant.
Old Jan 9, 2004 | 06:36 PM
  #41
cdtruckn's Avatar
cdtruckn
bump
Old Jan 11, 2004 | 07:44 PM
  #42
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
EMTABBMM
Happy New Year!!!
Please check and verify what "flash" update I have for my Excursion.
_______________________
03 Excursion Ltd. 6.0L PSD
Build Date 3/03
VIN #: 1FMSU43P43EC48106
Just had 15,000 mile service done at 12,300. Paperwork says flash or WDS was updated, but tech went on vacation and service writer doesn't know. Will the FMC "system" be able to tell?
I had the October flash done in November by Bonner Springs Ford. New dealer (better service) was done by Shawnee Mission Ford. Did I get December "flash" or did I get the new January flash that I heard or read somewhere???
IS there a January flash, and if so, what does it correct?
Please advise and thanks for your help... what a great site.
Thanks,
Old Jan 12, 2004 | 08:45 AM
  #43
"Luke" SdeS's Avatar
"Luke" SdeS
There is nothing wrong with mentioning dealership names
Fm BeachBumbCook / Jeff Cook
I had the October flash done in November by (((Bonner Springs Ford))). New dealer (better service) was done by (((Shawnee Mission Ford))). ....
Thank you, for there should be no fear in mentioning the names of the dealerships through which anyne is having either positive treatment or negative responses......
Old Jan 12, 2004 | 10:39 AM
  #44
emtabmm's Avatar
emtabmm
Originally posted by Beachbumcook
A: Happy New Year!!!
B: Please check and verify what "flash" update I have for my Excursion.
C: Just had 15,000 mile service done at 12,300. Paperwork says flash or WDS was updated, but tech went on vacation and service writer doesn't know. Will the FMC "system" be able to tell?
D: IS there a January flash, and if so, what does it correct?
A: Back at ya !!!
B: Only shows oct. flash but usually takes 2 weeks to get in Ford's system.
C: ask again later. (I feel like a kid's magic 8-ball) see line A
D: not yet...don't know
Old Jan 12, 2004 | 02:50 PM
  #45
SBV45's Avatar
SBV45
Your service dept will call it a 'recal' or recalibrate PCM.
For the December flash, the power seemed better because the shift points changed. Still not what it was. Mileage is still down.
