Sponsored by: Real Truck
rear end fluid
Old Jan 2, 2004 | 10:20 AM
ktm520mxc's Avatar
ktm520mxc
rear end fluid
I have a 2000 V10 F350 with the limited slip 3.73 rear end. Ford says to use synthetic 75-140 gear oil. My Ford dealer has it for $18.00 a quart! (I have the Mag-Hytec cover so I need 6 quarts).
I can get Mobil 1 synthetic gear oil for $7.00 a quart but it is 75-90.
Does anyone know if the weight difference would cause any problems? I live in Southern California so the temperatures are not too extreme.
Old Jan 2, 2004 | 10:08 PM
V10man's Avatar
V10man
Go with Royal Purple or Amsoil. Stick with the recomended weight.
Old Jan 2, 2004 | 11:00 PM
99f350sd's Avatar
99f350sd
make sure you use 75-140 as V10man says.. synth any brand will do. They do make gaskets for the rear and use the right stuff gasket maker in a can..you need friction modifier also...??
Old Jan 4, 2004 | 05:52 PM
V10man's Avatar
V10man
Both RP and Amsoil do not require the added modifier.
Old Jan 4, 2004 | 06:32 PM
DS02F250's Avatar
DS02F250
Just jumpin' in here...
At what mileage marker should the rear end oil be replaced? I have 60K on my 2002 F250 SD 5.4L 3.73 LS...
Thanks!
Old Jan 4, 2004 | 07:01 PM
99f350sd's Avatar
99f350sd
Ford says lifetime I think, but I like to change at 50k intervals.
Old Jan 4, 2004 | 08:39 PM
99PSDCREW's Avatar
99PSDCREW
I used Redline synthetic fluid on both differentials when my truck had 107K on it, seems good to go.
Old Jan 4, 2004 | 09:17 PM
Mud Doc's Avatar
Mud Doc
V10 man has it right. Your cover should have the drain plug so you don't have to bother taking the cover off. I have used Amsoil in my last 4 trucks, never a problem.
Synthetic in diffs should be good for 100K or lifetime if not submerged in water. Continual heavy towing may shorten that time--the rear diff gets very warm under load.
Old Jan 4, 2004 | 09:59 PM
DS02F250's Avatar
DS02F250
Looks like Royal Purple @ Jeg's is best price ($8/qt), free shpg + $9 handling charge= $59 for 6 qts.
Amsoil is $12/qt + $7.75 shpg = $80
Old Jan 6, 2004 | 06:33 AM
V10man's Avatar
V10man
J.C. Whitney has RP for $8.79 so that is a good price...
Old Jan 6, 2004 | 09:04 AM
DS02F250's Avatar
DS02F250
Jeg's: $7.99/qt. for 75w-140
Old Jan 7, 2004 | 04:26 AM
Mizzou's Avatar
Mizzou
If you plan on using alot of Amsoil then you can become a dealer and get a pretty decent discount for only 20 buck a year when I did it.
WestxSRT10
Nov 14, 2008 05:15 PM
Gage2502
Mar 2, 2008 09:00 PM
white Buffalo
Feb 19, 2007 07:00 AM
ktm520mxc
Jan 3, 2004 01:28 PM
eddie_1
Aerostar
Feb 4, 2001 10:35 AM
