351W an interference engine?
Old Dec 30, 2003 | 12:24 PM
gavin's Avatar
gavin
Sorry for the cross-post, but this is fairly urgent. Does anyone know if the 351w is an interference engine, or not?
THANKS!!!
Old Jan 1, 2004 | 07:20 AM
8 Lugs's Avatar
8 Lugs
No, it is not!
Old Jan 1, 2004 | 02:10 PM
gearshift101's Avatar
gearshift101
an interference engine ????
What is : an interference engine ??
Al
Old Jan 1, 2004 | 05:15 PM
gavin's Avatar
gavin
An interference engine is one that is designed such that if the timing element (chain/belt, whatever) breaks or gets out of place, the pistons can impact the valves if they are down when the piston is on the upstroke - you end up with bent/broken valves, scored pistons, bent lifters, even potentially a broken/bent cam. It ain't pretty, when it goes bad.
Old Jan 1, 2004 | 05:22 PM
gavin's Avatar
gavin
Originally posted by 8 Lugs
No, it is not!
Thanks, that's what I thought, but I wanted to make sure.
Old Jan 2, 2004 | 10:55 AM
gearshift101
Thanks for that info, Gavin
So! I guess it's a good thing, not to have an Interferance Engine.
By the way? I have a post thread "1986 f150 still bogging out"
maybe you can help me with my delemma?
Thanks: Al
Old Jan 2, 2004 | 02:08 PM
TowinBob's Avatar
TowinBob
I have seen Windsors bend valves when the nylon top gear loses its teeth. Not always, but can happen.
Bob
Old Jan 2, 2004 | 09:12 PM
hoxiii's Avatar
hoxiii
Is the 351HO an interference motor? If it is then that might explain why you've seen some that will bend valves and some that won't.
Justin
Nathan511
Jan 28, 2017 12:36 PM
fatheroftwo
Jan 29, 2016 07:00 PM
maverick1701
22
Sep 19, 2009 11:50 AM
cheetha94607
1978 - 1996 Big Bronco
Oct 10, 2005 02:01 PM
billyjoe
Aug 29, 2003 03:51 PM
