Seized Distributor in 460
Old Apr 28, 2011 | 05:45 PM
gottagojoe's Avatar
gottagojoe
Guessing most ppl out there have had this problem also, my Distributor is seized in my Block, Tried WD40 and some heat no luck, tried a pipe wrench which broke the entire distributor. now im out of ideas.
Old Apr 28, 2011 | 06:55 PM
LIF150's Avatar
LIF150
This was discussed not too long ago and you should be able to find the post where they talked about how they removed there frozen distributors. If my memory serves me correct, one member, used a engine hoist, chain, and hammer to get it out... Another used mouse milk... i think... some type of aircraft grade lubricant.... Anyway, give a search a try, im sure you will be able to find it.
Old Apr 28, 2011 | 07:14 PM
MiddleNameMUD's Avatar
MiddleNameMUD
I have been through this, exact situation hours of struggling which resulted in a snapped dizzy. I used PB Blaster let it sit for like 20 mins and gave her a twist... Wow cameright out, wish I tried that first! I now swear by that stuff... I put that s**t on everything! Like franks redhot... Lol
Old Apr 28, 2011 | 07:20 PM
Sleepy445FE's Avatar
Sleepy445FE
X2 on the PB blaster. That's what I have done and it's worked well. Sometimes it's still a little tough and you just have to work it back and forth trying to twist it. If it twists, it will pull out. If that doesn't work, I've dropped the pan and oil pump and hit the shaft from the bottom with a hammer and punch, comes right out that way but it's alot more messy. Better than breaking it.
Old Apr 28, 2011 | 07:36 PM
montana_highboy's Avatar
montana_highboy
PB blaster is great stuff, i use it myself, but a 50/50 mixture of ATF and acetone is even better, give it a try.
Old Apr 28, 2011 | 08:04 PM
LongTravelHighboy's Avatar
LongTravelHighboy
+1 on the above. PB Blaster didnt work for me. 50/50 Acetone and Marvel Mystery oil worked as instantly as a solvent can. Poured it on, waited 5 minutes, and tapped it with whatever was in my hand and it started moving. Its been free ever since.
Ed2
Jul 31, 2022 07:33 AM
Capecoraldad
16
Apr 21, 2018 08:51 PM
Mitchapalooza
Feb 24, 2016 03:38 PM
treverd
15
Feb 10, 2016 02:11 AM
jdmports22
Feb 2, 2016 06:44 AM
