1989 Ford 460 Distributor timing
Old Apr 23, 2006 | 09:44 PM
obars's Avatar
obars
I have a 1989 Ford F250 with 7.5L 460 EFI engine. I just replaced the distributor with rebuilt one. It has the distributor with the module on the side (no spade connectors, just has 6 small spade connector that connects to harness). My question is: What is the proper timing proceedure for this installation. I realize that the CPU will regulate timing, however, is there a staring point on installing distributor? As it is now, the enmgine starts and runs good, however it takes forever to idle down, and sounds advanced. Thanks- John
Old Apr 24, 2006 | 07:21 PM
subford's Avatar
subford
You pull out the SPOUT, highlight the timing mark, and hook timing light to number one wire.
Start the engine and turn the distributor to the mark, stop engine and tighten distributor, start engine recheck and readjust if it needs it.
Stop engine, put the SPOUT back in, restart engine and check for advance, if OK stop engine unhook light and you’re done.
Old Apr 24, 2006 | 07:48 PM
obars's Avatar
obars
What is the Spout????
Old Apr 25, 2006 | 07:09 AM
subford's Avatar
subford
The SPOUT (SPark OUTput) is the shorting jumper that opens the SPOUT information from the EEC to the ICM. With it out you are no longer under EEC timing control and you engine runs at Base Timing.
Here is a photo of it on a 1988 5.0. Sorry I do not have one for your engine but it should be in about the same place.
rupejosh
94
Dec 4, 2017 03:40 PM
lawsonej
May 31, 2016 07:40 AM
gunsandbeer
Apr 13, 2016 12:20 PM
gilllawn
Aug 24, 2009 11:58 AM
Powerstroke1995
Electrical Systems/Wiring
24
Oct 10, 2007 10:20 PM
