92 460 distributor problem
Old Apr 2, 2017 | 05:53 PM
humphrey169's Avatar
humphrey169
Hey what all can go wrong inside a 92 460 distributor. Had coil tested and replaced. Tested the fender mounted module and was good. Intermittent no spark condition.
Old Apr 2, 2017 | 05:54 PM
humphrey169
Fuel pump runs and the tach stops when this happens
Old Apr 2, 2017 | 06:14 PM
Conanski's Avatar
Conanski
The distributor contains a PIP module which is where the pulse for spark and EFI control originates. FYI.. the distributor has to be dismantled to replace this module so it's not something that can be changed with the dizzy in the motor.
P.S. I just noticed something in your second post. Do a quick test for spark when the problem occurs, if you still have spark the PIP module is good and your problem is with the PCM. Fuel pumps running constantly when the enigne isn't is a sign that the PCM has lost it's marbles.
whrvsc
Large Truck
Oct 29, 2010 10:33 AM
danlee
May 19, 2005 07:20 AM
farmsks
27
Jun 24, 2004 09:48 PM
cliffordthetruck
Electrical Systems/Wiring
Dec 20, 2003 10:22 AM
kvc2
1978 - 1996 Big Bronco
May 7, 2001 09:00 PM
