90 Ranger 2.9L Distributor problem
Old Dec 26, 2003 | 12:41 PM
fordranger7474's Avatar
fordranger7474
I'm having a problem reinstalling the distributor, it doesn't want to go in all the way. #1 is at TDC, rotor is pointing at #! but dist won't insert all the way. Feels like it is hanging up on the oil pump shaft, any suggestions?
Old Dec 30, 2003 | 06:03 PM
hreed's Avatar
hreed
I had the same problem on a 2.8. Not sure if its the same, but look down the hole where the distributor goes and see if there is a pin sticking up. This pin (at least on mine) goes into the center of the distributor shaft and was slightly bent. I managed to bend it back with a small screwdriver, and the distributor dropped right in. Have no idea why it is there. It's pretty hard to see in there-might try a mirror and flashlight. Hope that helps.
Old Jan 21, 2004 | 08:28 PM
snwcmpr's Avatar
snwcmpr
Thanks for the post, this helped me with the same problem.
oldsenile
May 23, 2005 11:55 AM
'73 250
Feb 16, 2005 11:28 PM
pfdnothing
Aug 22, 2004 09:49 PM
pcmenten
Feb 3, 2004 04:23 PM
jwxb41b
Apr 11, 2002 09:12 PM
