Distributor points cam moved!?
Old Feb 1, 2004 | 11:15 PM
pcmenten's Avatar
pcmenten
I was assembling the 223 for my truck and trying to get the distributor set in place with the rotor pointing to the post for the number one cylinder in the distributor cap. With the engine at TDC, it wouldn't line up. It would always end up between posts. I wonder if the points cam has moved.
I took it apart and relocated the cam on the distributor cam so that it lines up on the right edge of the post when the points start to open. Hopefully that will solve the problem. (Right edge because the vacuum advance will move it right to left. At full advance it ends up on the left edge of the post when the points start to open.)
Now the problem is that I can't get the danged gear back on the shaft. The holes for the rivet never did line up and now I can't get a roll pin to go all the way through.
Old Feb 3, 2004 | 04:23 PM
scroob's Avatar
scroob
Sounds like the hole is egged out on the shaft. It's possible to drill a new one but I wouldn't try it without a drill press to keep everything lined up when drilling. Maybe a rebuilt dizzy is in order.
RIKIL
Mar 14, 2012 07:35 PM
pidaster
Aug 30, 2011 06:43 PM
ErrorS
Nov 7, 2007 07:04 AM
Beanscoot
Sep 21, 2007 01:04 AM
pcmenten
20
Feb 21, 2004 01:15 AM
