Can anyone tell me if there is a difference in distributor shaft length on the 223 engine between 1958 and 1960? I'm trying to drop a distributor from one engine (1960) into another that doesn't have a distributor and it doesn't go all the way in. Thanks for any info.
From what I remember they should be the same. Starfox is correct, the distributor meshes with gear and pump. Check the slot direction on the pump and turn it with a hefty screwdriver if need be for alignment.
When i was replacing my dist gear and pump drive an old fella told me there was 2 sizes of hex shaft........maybe check that. Not sure what years he was talking about.
