Ranger heater core removal/replacement?
Old Dec 26, 2003 | 11:19 AM
babyblueoval's Avatar
babyblueoval
Thumbs down Ranger heater core removal/replacement?
I have a 1998 Ranger that was leaking antifreeze out of the heater core drain tube on the firewall. It was leaking very heavily. So for the moment i just bypassed it using the T fitting that was already in the system, the bypass worked great but now i need to get serious bout gettin that bad heater core out of there. I take it you have to remove the entire dash. I guess i dont really know how to go about that, i dont know where to start and i knot know what to remove and what not too. This seems like a pretty big job, for somthin small. If anyones done it before and has any tips id appreciate them. thanks
Old Dec 26, 2003 | 09:04 PM
bob arrington's Avatar
bob arrington
disconnect the hoses from the engine compartment , go under the dash on passenger side . remove the core cover and lower the core out . put the new one in and replace all covers and screws. install the hoses , and your done except for adding a small amount of antifreeze. thins process takes less than a half hour. if you take it to a shop they will chartge you 2 hours, good luck , Bob
Old Dec 26, 2003 | 09:09 PM
HomerWinzlow's Avatar
HomerWinzlow
Hmm, Im thinking the 98 is made like the Explorer, which requires removal of the dash, and the plenum assembly. Not a chore a rookie would likely find easy.
lawdogg_78
Sep 18, 2011 11:29 AM
BostiPB
1978 - 1996 Big Bronco
May 15, 2011 03:06 PM
babyblueoval
1983 - 2012 Ranger & B-Series
Dec 26, 2003 11:21 AM
ChiliD
Dec 11, 2002 08:39 PM
borland
Mar 22, 2001 02:31 PM
