Heater Core Bypass Valve
Old Mar 21, 2001 | 09:41 PM
borland's Avatar
borland
Anyone know how to test the heater bypass valve on a 95' Explorer?
The heating and AC are working properly, however I notice the hoses that lead to the heater core from the bypass valve are alway hot. The bypass valve picks up hot water from the intake manifold coolant jacket and delivers the return to the water pump. I'm assuming that the hot water should bypass the heater core when not using the heat setting. Is this correct?
The bypass valve's vacuum diaphram funtions with the temperature control panel settings, so it appears to be working. My 92' Explorer does not have this underhood bypass valve, so I assume the heater core always runs hot.
I have two manuals, but they don't cover this valve. Thanks!
borland
Old Mar 21, 2001 | 11:10 PM
PAUL_2's Avatar
PAUL_2
Thats correct , Unless the heater valve is directed to allow coolant to flow to the heater core , its doesnt flow to the heater core .
Old Mar 22, 2001 | 02:31 PM
stefan's Avatar
stefan
ddeflyer
May 31, 2015 04:35 PM
genscripter
May 4, 2014 07:50 PM
Bubba Jones
1978 - 1996 Big Bronco
24
Mar 19, 2014 10:55 PM
Tudunka
Jan 23, 2014 03:27 PM
Pinhead-227
1983 - 2012 Ranger & B-Series
Jul 11, 2008 07:32 AM
