Aerostar Ford Aerostar
93 aerostar Jerking
Old Dec 25, 2003 | 07:20 PM
SMOKETR's Avatar
SMOKETR
93 aerostar Jerking
My 93 aerostar jerks when you try to accilerate.It doesnt do it if you go to passing gear.I have replaced fuel pump,filter,coil pack and mas air flow sensor.I wonder if it could whatever controls the automatic over drive. Help
Old Feb 27, 2004 | 06:21 PM
johnwa's Avatar
johnwa
try replacing the o2 sensor, or cleaning the throttle body with the vehicle at operating temperature, empty 3/4 of a can of carb cleaner into the throttlebody reving up the motor just enough to keep it running, after you reach 3\4 of the can spray the rest of it in the throttle body causing it to stall, after the can is empty leave the van alone for 10 to 20 minutes, start it, you may have to pump it to let air into the combustion chamber to get it going, take for a drive accelerate fast, slow, fast ,slow and that will blow the crap out of the exhaust, I had this problem or similar before,
koalamazed
Aerostar
Aug 12, 2005 10:46 PM
77F-150
Aerostar
Mar 1, 2005 01:43 PM
noclue66
Aerostar
Jan 13, 2005 11:52 AM
fastestmom1960
Aerostar
Oct 24, 2004 09:22 PM
TheShadow
Apr 27, 2003 09:23 PM
