any one done this?
Old Dec 24, 2003 | 04:07 PM
KF4EYR's Avatar
KF4EYR
any one done this?
my 2.0 fuel pump failed and of course it went unnoticed until too late and gas was spewing onto #1 piston crank. so to make a long story short caused rings to break scarred cylinder wall to bad to fix. i found a 2.3 fuel injected a young boy had pulled from his ranger so as to put a 302 in. i asked around and a few mechanics said that a 2.3 could be used in place of 2.0,,,i took 2.3 and stripped all fuel injection stuff off and used 2.0 manifold (carberated) and exaust manifold bolted. they bolted right up to the 2.3 block,, the only thing i had to really mess with was the 2.0 had manual fuel pump the 2.3 didnt , i bought and installed a universal electric fuel pump. it starts and runs fine just a slight problem with the idle. if i could just bring it up some,, it is too low. just wondering if any one else has done this?
aaron
Old Dec 24, 2003 | 04:26 PM
hreed's Avatar
hreed
Put a vacuum guage on the engine. That will tell you a lot. You may have a leak. If not, you should be able to adjust the idle up with the idle adjustment screw on the carb.
Old Dec 24, 2003 | 08:39 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
Old Dec 25, 2003 | 08:27 PM
KF4EYR's Avatar
KF4EYR
where is the idle adjustment screw? i havent been able to find anything to adjust idle with. thanks kf4eyr
Old Dec 26, 2003 | 08:15 AM
surelly09's Avatar
surelly09
There should be an adjustment screw on the carb as well as a air/fuel mixture set of adjusters. I am not exactly sure where but I am sure if you ask in the Engine forum someone there will be able to help you.
FordCamping
May 21, 2016 07:58 PM
FordCamping
Modular V10 (6.8l)
28
Feb 27, 2014 09:45 AM
postmaster ford
4 Cylinder Engines
May 24, 2012 12:04 PM
akamacgyver
Nov 19, 2011 07:08 PM
Paco_Jones
Oct 11, 2009 07:14 PM
