Turn signal Problems
Old Dec 20, 2003 | 04:16 PM
Joshnelson1's Avatar
Joshnelson1
Blinkers Busted Help
Ok, I have a 1977 ford f100 stepside.
For some reason my blinkers aren't working.
The T/S indicators or even work & I dont have a clue what to do.
The guy at an autoparts store told me to change the signal's fuse, but the truck is so old that it doesnt tell me were it is.
The names are rubbed off does anyone know were i can get a manual for free online or can someone like scan a copy of the fusebox in your manual so i can see which fuse i need to replace?
Old Dec 20, 2003 | 05:34 PM
sparky's Avatar
sparky
Should be a 15amp fuse 3rd from the top on the rh side when looking at the panel.
It also feeds the windshield washer and backup lights...are they working?
Old Dec 20, 2003 | 07:03 PM
Mil1ion's Avatar
Mil1ion
These should help.
You can save them to your computer by holding the cursor over the pic than right click the mouse.
Old Dec 20, 2003 | 09:55 PM
Joshnelson1
that picture i canot see can u sharpern it
Old Dec 20, 2003 | 09:57 PM
Joshnelson1
my washing fluid isnt working but my winsheild wipers are and my reverse lights arnt working either its to dark here so i will see if i can replace it in the morning and get back to you
Old Dec 20, 2003 | 11:04 PM
Mil1ion's Avatar
Mil1ion
Josh,
I was going to e-mail the photo so you can see it better.
You have 2 user names.
I sent you an e-mail, Please watch for it.
Old Dec 21, 2003 | 11:06 AM
Joshnelson1
Mil1ion I have just received your email thank you for helping me out and yes please delete one if you may.
Thanks
Josh Nelson
Old Dec 21, 2003 | 11:28 AM
Joshnelson1
I put all the fuses were they need to go according to the diagram and yet the turn signals are still not working
Old Dec 22, 2003 | 07:38 PM
Cmotif's Avatar
Cmotif
I have my 1978 F-100 in the shop right now with similar turn signal problems. Left sides don't function or show on the dash, but the right side does. How does the turn signal stalk feel when you are trying signal? Mine feels sloppy, like there is no detent for right, center or left.
Cmotif <><
Old Dec 22, 2003 | 09:21 PM
sparky's Avatar
sparky
So do the windshield washer and backup lights work now?
If they do try the flasher unit for the turn signals next, you can always swap it with the emergency flasher one. Do the emergency flashers work? How about the brake lights?
If that doesnt fix them it is time to start some voltage checks......do you have a test light or a multi-meter?
Old Jan 4, 2004 | 01:17 AM
kermit's Avatar
kermit
had a very similar problem last week. both were working, then the right side quit working, inside, outside, all together. left side worked like normal, and so did the hazzards. then about 2 days later, the left side quit working. took the steering wheel off, pulled the plate with the t/s switch, hazzard switch, etc out and found the blue wire coming from the t/s switch was broken. fixed the wire, now everything works perfect again. just a thought.
Myfirstnewtruck
1997 - 2003 F150
Dec 13, 2023 03:01 PM
domslude
21
Mar 2, 2021 02:28 PM
gritsngumbo
Aug 20, 2007 10:58 PM
kidzstang
1997 - 2003 F150
May 20, 2004 09:01 PM
2explorers
Jun 26, 2003 05:40 PM
