New Ignition System
Old Dec 19, 2003 | 10:17 PM
79pos's Avatar
79pos
New Ignition System
I've been looking for a good ignition system and am undecided on msd or crane. Does anyone have any recommendations. Maybe even part numbers.
Oh its a '79 f-150 4wd with a 351M/400
Old Dec 19, 2003 | 10:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
You can edit your own posts for up to an hour after you make them.
Keep the stock Duraspark system. it is the easiest to work on and if you need parts they are cheaper and easiest to get. You can heave them tested at most parts stores. The stock system is as good or better than MSD or Crane units up to around 6000 rpm and you won't be running your stock motor or even mild rebuild any higher than that. The stock system also has a spark retard function for easier starts. Mount the stock MOTORCRAFT module (the best) 1/4 inch off the fender for better cooling.
Old Dec 20, 2003 | 01:13 AM
biz4two's Avatar
biz4two
For several years now, I have been using the Jacobs ignition system. They are pricey, but you get a lot too. Also go with the 8.5mm wires too.
They require NO splicing of wires and the original coil stays put. No need to remove. Should the system ever fail, simply remove the Jacobs coil wire and fuse to positive and re-install the original coil wire to distrib and off you go.
FACTS After the install:
a.) 1.5 - 2 mpg better consistantly
b.) smooth ideal and easy start up's
c.) have checked spark plugs and look great...igniting the fuel perfectly.
Recommend:
Mileage Master Kit (part # 372446)
Off-Road Kit (part # 373546OR)
Pro Street Kit ( part # 372546)
Ultra Fit spark plug wire set
http://www.jacobselectronics.com/
Good luck finding what works best for your application.
Old Dec 20, 2003 | 05:53 AM
skuteman's Avatar
skuteman
Davis Unified Ignition makes a GM style HEI style Distributor for fords with everything in the distributor . No external boxes to mount, hookup or go bad. I think they run around 300........s.kuteman
Old Dec 20, 2003 | 11:15 AM
79pos's Avatar
79pos
Now I've got a few places to check.
Appreciate the help.
Old Dec 29, 2003 | 08:07 PM
pro3qtr's Avatar
pro3qtr
Stock ford distributors suck, so I went to msd billet in my 460.
Old Dec 29, 2003 | 08:18 PM
Torque1st's Avatar
Torque1st
Posting Legend
There is nothing wrong with the OEM Ford distributor, unless of course it is worn out, which can and will happen to any distributor. Make sure that any distributor that you use for a replacement on a street driven vehicle has a vacuum advance. Many replacement distributors do not have the vacuum advance are only suitable for racing applications.
Old Dec 29, 2003 | 09:09 PM
pro3qtr's Avatar
pro3qtr
Well speaking from experience, the rebuilds are JUNK here in Wa
I went threw 10 distributors.
MSD makes a PERFECT street dis for all ford engines and have Vacuum advance.
Also the mechanical advance is more performance oriented.
The Mechanic
Old Dec 29, 2003 | 09:17 PM
f100guy's Avatar
f100guy
there is a company called DUI and they build custom HEI distributors for any application. you tell the what cam you have what cfm carb and what the motor is going to be used for. they run for about 300 dollars.
Old Dec 29, 2003 | 09:21 PM
Torque1st's Avatar
Torque1st
Posting Legend
Some of those rebuild companies can be a problem. Call around and find a different brand if you have problems with a particular brand. I had mega problems with A1/Cardone rebuilt PS pumps. I called around and found an ATSCO unit that worked perfectly.
Whatever distributor you get it needs to be tuned to your engine if you have done any modifications. This can be done with a distributor machine and a Dyno.
Old Dec 29, 2003 | 10:26 PM
Matts72's Avatar
Matts72
My dad swears up and down by Crane cams Fireball Hi-6 buzz boxes and mallory distributors. why should I disagree, he can get 15 mpg out of a 390, and thats definetly an oddity.
I don't have any experience firsthand with the MSD boxes, but they are on all of the race cars around here.
Old Dec 29, 2003 | 10:38 PM
Torque1st's Avatar
Torque1st
Posting Legend
MSD is supposed to have a replacement for the stock duraspark box that has a start retard function etc. The aftermarket boxes will not do any better (some are actually worse) than the OEM ignition systems. The GM HEI and the Motorcraft Duraspark boxes are good stuff. The aftermarket boxes will do better than the OEM boxes above 6000 rpm but how often does a street truck or daily driver see that? Some of the knockoff copies are junk tho. The later Ford TFI ignition system modules are often a POS tho. That may be due to improper installation many times. The OEM boxes are easily tested at any good parts store, replacements are available everywhere, and they are much cheaper than the aftermarket units.
The racers use the MSD stuff because you can get so many little tuning widgets to go with them but at the same time they have a hot spare ready that can be used with a flip of a switch. That does not say too much for reliability in my books.
Old Dec 30, 2003 | 07:43 PM
SeaDooPhil_78's Avatar
SeaDooPhil_78
Those OEM FORD Motorcraft Duraspark systems must be pretty good, they seem to last, especially if you put spacers under them like Torque1st said.
When an old Ford goes to the junkyard to be a parts donor, the Duraspark system is one of the first things to be taken off and re-used.
I like mine because it is the only thing left on my truck that I haven't replaced.
Phil
Old Dec 30, 2003 | 11:48 PM
pro3qtr's Avatar
pro3qtr
Never said the box was bad, just the distributor.
If U can find one !!
Old Dec 31, 2003 | 03:18 AM
Torque1st's Avatar
Torque1st
Posting Legend
Look around, some machine shops and speed shops have distributor machines. If you had the stuff in my shop you could rig one up to test a dizzy. Some individuals with extensive shops have actual distributor machines. Ask around in the local chapter forums. Ask at the good parts stores, ask old mechanics. Larger cities frequently have several dyno's. There is one just a little ways from me. A dyno run is worth the cash to dial your engine in.
acethunder
Feb 6, 2012 09:06 PM
79FordBlake
26
Aug 7, 2010 12:26 PM
Fordman79
29
Jan 22, 2006 10:52 PM
luckytruck79
Electrical Systems/Wiring
Dec 3, 2004 10:08 PM
Trav
Sep 11, 2002 07:41 AM
