79 dash brake light
Old Feb 6, 2012 | 02:54 PM
acethunder's Avatar
acethunder
79 dash brake light
quick question, when i turn on the ignition and start the truck should the brake light come on as a system test or should it always stay off unless there is a brake issue?
Old Feb 6, 2012 | 03:14 PM
ctubutis's Avatar
ctubutis
It comes on as a system/light bulb test.
Old Feb 6, 2012 | 03:17 PM
acethunder's Avatar
acethunder
okay, mine only comes on when you try starting in a gear or if the shifter isn't completely engaged into park or neutral. Where so i start to try and figure out a solution? thanks for your help
Old Feb 6, 2012 | 07:49 PM
fmc400's Avatar
fmc400
MSEE
As stated above, the bulb should come on as the key is turned to START. The ignition switch has a PROVE-OUT terminal to ground out the bulb as the key is turned.
You're saying the bulb will not come ON if you try to start the truck in PARK? Power to this circuit has nothing to do with the neutral safety switch, so it's completely agnostic as to what gear the truck is in. Has your wiring been modified at all?
Old Feb 6, 2012 | 08:23 PM
acethunder's Avatar
acethunder
yeah someone put in a trailer brake and jumped the red wire from the brake switch to the trailer brake. why i do not know.
Old Feb 6, 2012 | 09:06 PM
fmc400's Avatar
fmc400
MSEE
I can't tell you what's wrong because I don't know what the previous owner did. Here are some wiring diagrams (1979 at the bottom) if you want to trace through it yourself.
1973-1979 Ford Truck Wiring Diagrams & Schematics - FORDification.net
Riderman
Nov 13, 2022 02:16 PM
alchemist1
16
Apr 17, 2014 09:42 PM
oldbird1965
25
Jan 24, 2014 10:01 PM
nicholls77
Jan 19, 2007 01:57 PM
elstx
Electrical Systems/Wiring
Dec 28, 2003 05:28 PM
