Over Heating ?
Old Dec 16, 2003 | 05:21 PM
CrazyLarrY's Avatar
CrazyLarrY
Question Over Heating ?
I have been restoring a 1970 Ford F100 390 for a year now and have replaced most of the engine and pumps on it. I replaced the thermostat a week ago {160 degs} and now the instrument panel is lighting up all lights very dimmly {with or without the lights on} and the temp gauge bottoms out on the H. I replaced the Panel dimmer switch thinking its a electrical problem there, but no luck. Any ideas ?
Old Dec 16, 2003 | 05:42 PM
BB's Avatar
BB
Hi and welcome to the site!
First thing I'd do is verify that the engine is really not overheating say from a stuck of backwards stat. Stick a thermometer in the rad and see what it reads. Then I'd go from there.
Barry
Old Dec 16, 2003 | 05:51 PM
BB's Avatar
BB
I think I'm gonna stop giving advice for a while because it's really sucked lately. You're not gonna see anything with the thermometer in the rad if the stat's stuck 'cause all the hot coolent is stuck in the engine. Anyway, determine if the engine is really hot or not.
Old Dec 16, 2003 | 06:20 PM
lrd56's Avatar
lrd56
bigger radiator
i put in a rad out of a 77 b600 bus it fit great. it is a little longer than a reg rad but you should not have any more overheating trouble .
Old Dec 16, 2003 | 06:35 PM
NM5K's Avatar
NM5K
You did something to your wiring. Something is grounding out or something along those lines if your lights are on when off, and the gauge is bottom pegged. Check the coolant sensor wiring under the hood. Check for any wiring that might be grounding out.
Being this happened when you changed the stat, sounds like you bumped some wiring or something. You probably are not overheating. Actually, I prefer a hotter stat than 160 degrees though. You have less efficiency and more engine wear with the cooler stats. Heater not as good either... I run the stock 195 degree stats. But to each his own in that dept... MK
Old Dec 16, 2003 | 07:25 PM
CrazyLarrY's Avatar
CrazyLarrY
Thanks for the info guys ill check the coolant sensor wire and maybe change the themostat to a 190 deg later on.
Old Dec 16, 2003 | 07:41 PM
f100guy's Avatar
f100guy
wouldn't that make it overheat faster. 195 are bad out here in tx
Old Dec 17, 2003 | 12:53 AM
NM5K's Avatar
NM5K
I'm in TX too. No problems here so far. The thermostat really has little to do with whether you will overheat or not, as long as they are working properly. All it does is limit your temp to 195, or whatever temp stat you stick in it. As long as you have the radiator capacity, it won't ever go much higher. No overheating. The only way for it to overheat is for the radiator not being able to keep up. IE: clogged up, etc. If you live in a very hot place, you should still use the same thermostat, but you might consider a higher capacity radiator. If you overheat, it's the radiators fault, not the t-stat, assuming all else is normal.
Low stat temps cause more wear and less efficiency of the engine. Heater is not as good. In some cases, more sludges, etc can build up. Engines are actually happier in general when they are fairly hot. To a limit anyway...If 160 was better, ford would have used that in the first place. As far as I know, they didn't vary the stat temp according to final delivery area. They all were the same. Alaska to Arizona. Or as far as I know anyway... :/
I use 195, and would anywhere I'm at. And it gets hot here in the summer... No worries mate, as crocodile man would say...MK
Old Dec 21, 2003 | 07:46 PM
Opiewan's Avatar
Opiewan
i live in iowa and when it cold here i cant get warmed up enough. i gotta get one of those 190 stats, my new 160 leaves me shivering all the way to work.
Old Dec 22, 2003 | 12:59 AM
NM5K's Avatar
NM5K
I gotta have a good heater...I can drive with no A/C all summer long with no problems. But I can't live without my heater. I guess I'm cold blooded like a snake...I'm glad all mine took to work was a new control valve. The original valve was totally rusted out and broke in two pieces... MK
tndallas
Oct 14, 2016 01:57 PM
alchemist1
28
Jun 11, 2015 10:04 PM
BaltoMoJoe
Oct 7, 2014 09:02 PM
Brown Falcon
Oct 23, 2010 04:41 PM
Mormakil
Aerostar
Jul 2, 2006 07:03 AM
