Front header panel removal?
Old Oct 23, 2010 | 08:58 AM
Brown Falcon's Avatar
Brown Falcon
So I was told that I need to remove the header panel in order to replace my headlight housings.
What all do I have to do to remove it?
I know I have to take out the headlight surrounds/corner and parking lights first, remove the grill.....
Where are all of the bolts for the header panel? Any tricks?
Old Oct 23, 2010 | 02:18 PM
fordpride's Avatar
fordpride
i did mine with out takeing the header panel off it wasn't to bad i removed the grille took out the batts. and the there is 2 screws on the to of the light surronds and under the batts theres 2 10mm nuts behind the park lights you got to get to take the surronds off after they are off if you look behind the headlight you will see some locks on the back of the headlight adjustment bolts that have to be pulled offand the lihgt will pop out
Old Oct 23, 2010 | 02:34 PM
Action4478's Avatar
Action4478
The nuts for the Light bezel are 11 mm unless some one changed them ...
If you can get to the HL Clips, an angled pair of snap ring pliers work well for removing them ...View A ,shows the clip...
Name:  HEADLIGHT HIDDEN NUTS.jpg
Old Oct 23, 2010 | 02:48 PM
fordpride's Avatar
fordpride
mine are after market this truck has been wrecked very hard
Old Oct 23, 2010 | 04:41 PM
Brown Falcon
Thanks guys. Doesn't look too hard.
Pele
Jun 9, 2017 09:55 AM
DirtWorx
17
Nov 13, 2016 06:26 PM
John7894
Mar 8, 2013 08:54 AM
bahtsata
Nov 14, 2011 06:38 PM
ErrorS
Jan 11, 2005 10:47 AM
