I disabled my wastegate actuator for about 10 minutes tonight...went on a 3 mile test drive, and the flutter and surge were so audible with it disengaged that I just had to plug it back in. (TYMAR) Didn't notice much if any performace difference either, but that may have been because I was listening to the noises.. Never got it to defuel though...
Originally posted by cookie88 No suprise there. You add more air to a wheel that's already stalling and it gets worse. You'll notice the improvement once you get that wheel in.
I can't wait to get it in...should be on its way here by now, ready for install next weekend!
You probably won't get an SES if you are running the PPIII in your sig. It just can't put in enough fuel to get the boost that high.
It isnt a PPIII--It is an actual Hypertech Chip that came with the truck when I bought it. Don't know anything about it other than people I bought it from told me it was 50 HP and 80 ft/lb. I can't find anything about them anywhere. I have taken it out before and can't stand driving it without the chip--makes a pretty big difference. Can't wait til I get something decent, so I know what a good chip can do. What would you recommend Cookie--Mostly empty running but some moderate to heavy towing, primarily flatlands, 8000-15000#. Want to stay away from smoke. Thinking about Predator or one of the 4 position chips....
Ok, so after reading this thread, I disconnected my wastegate. Yes it does spool up faster. That's a good thing. I've ran in for about a week, and tonight i was going up a grade and the SES light came on. I knew why, but I read on here that the PCM would defuel.. but I kept accelerating. I thought defueling would slow me down?!?!? any clues? And the light is still on after three restarts...
By "defuel" we're not talking about the PCM just shutting off the fuel. The PCM knows it has to limit the engine to X amount of boost, the problem is it is already past that when it start's to try (when it triggers the light) and all the other inputs are telling it that you still have your foot to the floor, so it has to walk the line between controlling the overboost condition and keeping enough fuel to accomplish the high load task.
Clear as mud? Normally what that means is that you won't actually feel it defuel until you defeat the light, it just won't pull quite as hard as it should be.
That is not normal. Unhook the batteries (with the headlights on) for a half hour or so and see if it clears. If not have the code read. The overboost, high backpressure, and ICP high/low codes will reset on the next drive cycle, so you migh have something else going on.
Originally posted by cookie88 By "defuel" ..... Clear as mud?
Yup! Clear as day!
Ok, so i gave up too soon. I popped the hood and went to disconnect the batteries. Then I thought, what the hay, might as well check it one more time... and voila, the light went out on the fourth restart. I's been off for the past four drive cycles.
Originally posted by Strjock81 Higher boost that would have been released by the wastegate. I am not really sure as to how much extra boost you get...seems to me like it is there for a reason but I am just learning to, so I am interested in seeing what the answer is exactly. I wouldn't mind doing mine if I am going to see a big improvement.
why don't you just put in a boost controller? that way you can adjust it and also still have the waste gate there so you don't break anything
A boost controller is wasted effort on a diesel. You are only going to make as much boost as the fuel will allow, and with the wastegate still active it won't even spool any faster than normal (ask me how I know). Besides, the only thing the wasgate is protecting against is exhaust backpressure, and if you have an EGT gauge, you're already protecting yourself.
need help.....how can i test the wastegate actuator? thanks
