Sponsored by: Auxito
bad squeak
Old Dec 16, 2003 | 04:21 PM
lance-242's Avatar
lance-242
bad squeak
hi, i have a '97 F-150 4 wheel drive w/104000 mi. the truck has been pretty good so far. leaking back window, 2 oxygen sensors, knocking while cold and terrible spark plug changes. recently the worst has happened. it sqeaks loudly on small bumps. i mean SQUEAKS! it's embarrassing. any suggestions?
thanks
Old Dec 16, 2003 | 05:33 PM
emtabmm's Avatar
emtabmm
ball joints, radius arm bushings....etc.
Old Dec 16, 2003 | 08:54 PM
Racerguy's Avatar
Racerguy
Try spraying down all the bushings in the front end with WD40 or silicone spray. If that doesnt help then you probably have a squeeky ball joint or tie rod end. If you can get it to do it while someone bounces up and down on the bumper you should be able to pinpoint the noise if you crawl underneath and start listening to and feeling each joint as it squeeks.
Old Dec 24, 2003 | 11:07 AM
roland98's Avatar
roland98
Where does the squeak seem to come from? The steering? Or maybe under the cab? Does it do it only when you hit bumps, or when you are turning?
-R
Old Dec 24, 2003 | 06:27 PM
lance-242's Avatar
lance-242
it sounds like its coming from the right front wheel on any bumps on the road
Old Dec 30, 2003 | 10:46 AM
habs10's Avatar
habs10
I had a sliding rear window that also leaked. The dealer put new black silicon between the window frame and the body, didn't work. Finally I ran water from a hose over the roof and it went down the back window. The leak was around the glass itself, not the frame. I squeezed a whole tube of Versachem (I think) glass sealer in the gap, no problems since.
Old Dec 30, 2003 | 11:05 AM
Racerguy's Avatar
Racerguy
Hi habs10 and welcome to FTE
Is Versachem a silicone sealant?
Truck55
1997 - 2003 F150
Jul 29, 2012 08:17 PM
maxtruck00
May 22, 2009 12:52 PM
creature84
Mar 9, 2008 10:33 AM
goatdriver
2004 - 2008 F150
Jun 3, 2007 07:47 PM
LJ-mar
Aug 2, 2003 07:38 PM
