Walbro fuel pump
Old Jun 17, 2026 | 11:24 AM
90project5.0's Avatar
90project5.0
Walbro fuel pump
I’m looking at putting a Walbro fuel pump on the truck. It only has one tank on it. My plan is a 190 lph pump. Any advice on the install and what part number did you use?
By fall time, I will be doing work to put me around 350 hp/tq range.
I’ve owned the truck 3.5ish and this is the 4th time I’ll be replacing the “lifetime warranty” pump. This time it left me stranded at a grocery store with my landscaping trailer!! I’m truly tired of this. Replacement warranty pump won’t come in until
this afternoon and I’m supposed to get two days of rain starting tonight. I had 7 more lawns to do!
Rant over…
Old Jun 17, 2026 | 12:24 PM
rwfid's Avatar
rwfid
Which pump are you going with? I've heard that they have some high volume in tank pumps out now that would probably be the way to go. I've got the GSL392BX pumps which are 255 lph. I haven't had one fail me in the 4 years that I have been running it, probably because I bought a couple of spares for just in case. Walbro suggests using a 100 micron pre filter, so I ended up with an Aeromotive 12319. Definitely, DO NOT waste money on a small prefilter. You will be constantly changing them when your engine starts leaning out.
Old Jun 17, 2026 | 12:46 PM
90project5.0
In tank is my plan. I would love to just go with a rail pump if it would pull through the FDM without a problem.. I’m tired of dropping the tank! I was looking at the LMR kit for a mustang:
https://lmr.com/item/LRS-9350B/1986-...s242-Fuel-Pump
$10 more and I can do 255, but I didn’t feel like it was fully necessary. Maybe just say screw it and do the 255. Looking on their site, there are 3 types to choose from, all based on sock type/location on bottom pump.
Old Jun 17, 2026 | 04:38 PM
90project5.0
I had a convo with the O Reilly manager and told them I was tired of changing it out so frequent and I lost most of my income for the day, potentially the week with the weather. I said I was going to swap to another fuel pump really soon. She actually said she agreed and was good with me returning the new one in the truck now for a full refund. If i go the Walbro route, I’ll need to go to a junkyard and get another fdm. That will still leave no money out of my pocket essentially.
O Reilly pump is $150
255 Walbro kit is $114. I can’t imagine a JY pump will be more than $30-40.
Anyone have a junk fdm for a front tank they want to part with?!
Old Jun 18, 2026 | 07:59 AM
1Butcher's Avatar
1Butcher
Going through the experience with a 'lifetime' warranty part from the big box stores is a real lesson learned. Preach to others about what the term 'lifetime' means. It's a lifetime of repairs done on the side of the road. This applies to starters, alternators, etc. It's just not worth it. Spend twice as much money for something that is good but only has a two year warranty.
The problem with used is they are old and fuel pumps tend to wear out vs break. The brushes in the electric motor tend to wear out which is why they just stop working. You could buy a used pump assembly and then swap the pump. I did that when I upgraded the rear pump to a larger 255lph pump.
Old Jun 18, 2026 | 09:21 AM
Hit Man X's Avatar
Hit Man X
You could do an early intank as it is a low pressure/low volume and feeds an inline...then pop a Walbro 255 inline down on the frame. Inlines push far better than pull.
No need to fart with that switch valve like I have on my 88.
Old Jun 18, 2026 | 11:12 AM
90project5.0
That is my plan, swap the pump in the used unit. I looked for a motorcraft pump, but could not locate one for the 16 gallon midship. That’s why I went with lifetime vs cheaper 1 yr.
Old Jun 18, 2026 | 11:13 AM
90project5.0
too bad you can’t just add a high volume to the older low pressure setups. I have been toying this idea as well. Easier to swap when it craps out.
Old Jun 18, 2026 | 03:38 PM
90project5.0
True to form with the “lifetime warranty” crap. See pic below. The new o ring decided it wasn’t right for the job… Soo happy I could dump fuel on the ground at a clients house as their landscaper.. wasn’t caught yesterday as I only had 1/8 tank. Had to fill the mower and gas can so I filled the truck also and then went back at it.
Got the truck home, dropped tank and put old o ring back in. Problem solved..
Old Jun 18, 2026 | 03:49 PM
Hit Man X's Avatar
Hit Man X
Lame!
Old Yesterday | 01:56 PM
90project5.0
@1Butcher did you have to do any modification to the housing or was it a straight swap job?
Old Today | 08:56 AM
1Butcher's Avatar
1Butcher
Pretty much a straight forward swap. The pump is actually a bit larger [diameter] than the stock one and the housing does not snap together completely. I did not take pictures, but I don't recall too much butchery to make it work. I am 100% certain there will not be a problem. When I replace the front pump, I will take pictures. I don't plan on swapping the pump this year, but who knows. I do want to replace the pump before I put in my 408w.
This is the pump I used.
https://aeromotiveinc.com/products/3...e-center-inlet
Old Today | 09:30 AM
90project5.0
Awesome, thanks!
Old Today | 09:33 AM
1Butcher's Avatar
1Butcher
I am not a fan of over pumping fuel. You need a big enough pump to handle the needs of the system and that is about it. Since I am going to run a supercharger, I need that much pump.
Frank79
Jun 8, 2022 06:01 PM
my94red4x4
Oct 18, 2020 08:24 AM
dannierogg
Nov 20, 2009 04:14 PM
tseekins
40
Sep 9, 2009 07:53 PM
