Fuel pump issues
Old May 28, 2026 | 03:04 PM
mbooth236's Avatar
mbooth236
3rd Gear
Fuel pump issues
Hello everyone, I recently changed the front fuel pump in my 1990 f150. I did make sure to swap over the check valve from the old pump but I’m having issues with sputtering at idle and during acceleration. Everything functions normally as soon as I swap to the rear tank so I’m just looking for some ideas before dropping the tank again…
Thanks guys!
Old May 28, 2026 | 04:29 PM
90project5.0's Avatar
90project5.0
Two things, verify fuel pressure at the test port on both tanks. Second, did you verify the check valve was functional before reinstall? Mine were screwed up. Supply line was stuck almost completely closed and return line was stuck fully open. Both rusted in place.
Old May 29, 2026 | 06:55 AM
manicmechanic007's Avatar
manicmechanic007
Unless everything runs perfectly and the pump just quits
Replace the "fuel pump module assembly" that has both the check valve and shuttle valve new in the module
And
Plan on 3 pumps in 2 years if you buy the cheap module assemblies
Aus f150
May 22, 2025 10:02 AM
tony b
Nov 4, 2006 10:10 AM
moose94
33
Jun 30, 2005 12:03 AM
yabbieboy
Feb 10, 2005 05:08 PM
Broncobirdy
1978 - 1996 Big Bronco
Apr 3, 2004 05:30 PM
