LED taillights
Old May 27, 2026 | 06:48 PM
Ar. Hillbilly's Avatar
Ar. Hillbilly
LED taillights
Probably a dumb question, but what would I have to do to run LED taillights on my flatbed.
I can only find the lights I want in LED.
I’d like to run the stock front turn signals.
Old May 27, 2026 | 10:42 PM
cwegga's Avatar
cwegga
Probably just run an LED compatible flasher. I like this one, but they say if you are replacing too many bulbs to get a grounded one instead.
https://www.hipoparts.com/12v-heavy-...-relay-module/
Old May 28, 2026 | 02:00 PM
jamiedrchiro's Avatar
jamiedrchiro
I am in the process of switching to all leds. I had to get electronic flashers (with a ground wire). One thing to note, they only plug in one way, however, mine did not function plugged in that way. I had to make pigtails and reverse the connections in order to get mine to work properly.
So if you get them and they do not work, try reversing them before you start chasing a rabbit that isnt really there.
Old May 28, 2026 | 05:16 PM
Ar. Hillbilly
thank you
Old May 28, 2026 | 05:18 PM
Ar. Hillbilly
thank you
Old Yesterday | 07:31 AM
WolfeW's Avatar
WolfeW
6th Gear
If you’re running stock filament bulbs up front, the led flasher probably isn’t necessary. There should be enough resistance to make the old style flasher work. Nothing wrong with replacing the old mechanical flasher with an electronic one. One of those “while you’re in there” kind of things.
Old Yesterday | 08:11 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
If resistance makes the flasher function with incandescent bulbs, then LEDs should work better as they have near infinite resistance.
Which is why LEDs DON'T work with standard flashers.
Current draw is what makes a standard flasher function - a byproduct of LOWER resistance.
This is why the resistors that are sometimes required for proper flasher operation are wired in PARALLEL to the stop/turn power and ground wiring.
Old Yesterday | 06:31 PM
egchewy's Avatar
egchewy
With that rationale, will a LED specific flasher with with regular bulbs? I’m in a situation where I’m rebuilding with LED taillights but regular headlights
Old Yesterday | 07:58 PM
motorsickle1130's Avatar
motorsickle1130
You’ll be fine. If the flashers don’t work, just switch to an LED style flasher, and as noted above you’ll probably have to reverse the polarity.
Ive been running all LED rears, fronts, and side runnings for about a year. Just bought the whatever brand off Amazon and have been mostly happy with them.
Also could install relays to trigger the side markers to act as turns too. It’s on my to do list just not very high at the moment.
red21sweep
15
Jan 30, 2026 06:56 PM
troverman
2017 Ford SVT F150 Raptor
Sep 13, 2017 10:09 AM
jd52cranbrook
1947 and Older Ford Trucks
Jan 26, 2014 02:53 PM
Mike's 77
May 20, 2008 03:53 PM
nskitts
Nov 20, 2006 12:42 AM
