Turn signals question, please help!!
Old Nov 17, 2006 | 08:31 PM
nskitts's Avatar
nskitts
OK,
I'm trying to get a 1979 F-150 4X4 back on the road after ten years sitting and the headlights work, taillights and brakelights work, but the front running lights and turn signals do not work. The bulbs are good and there appears to be juice running to the lights as I used a light meter on the socket and it lit up..now on the dashboard, when I turn the signal on the indicator comes on and stays on until I cancel the signal, likewise when I turn the parking lights on, both indicators come on. Please help, I am totally ignorant when it comes to lighting. Thank you.
Old Nov 17, 2006 | 09:14 PM
timothy47129's Avatar
timothy47129
Try to clean the bulb contacts with a small wire brush.While the lights are off of course.
Tim
Old Nov 17, 2006 | 09:26 PM
Bdox's Avatar
Bdox
"the front running lights and turn signals do not work."
Do you mean ALL the turn signals don't work? Do any of the bulbs light up when your try to operate the turn signals?
Did you check the front running lights with the switch in the parking light position? In some trucks the front running lights are off with the headlights on.
Did you try a different flasher unit?
Possibly the ground for the front lights is bad.
Old Nov 17, 2006 | 10:18 PM
Torque1st's Avatar
Torque1st
Posting Legend
There is a nice tech article on chasing light problems. Check the top menu bar.
Old Nov 17, 2006 | 10:23 PM
nskitts's Avatar
nskitts
None of the turn signals work, not even the back. What do I do if the ground lead is bad on the connector? I will try the sandpaper/wire brush tomorrow.
Old Nov 18, 2006 | 04:33 AM
5851a's Avatar
5851a
Sounds like the same problem with my 78. Over the years I've replaced all of the bulb sockets. The ground wire inside the socket is made in 2 pieces and they corrode and rust. Sometimes you can push and pull on the ground wire enough to get it to work for awhile. You can check the ground by leaving the bulb in place, turn on the signal and use a jumper wire from ground and touch the ground contact around the bulb. You can get the replacement sockets at most of the auto parts places.
Old Nov 18, 2006 | 11:09 PM
Mil1ion's Avatar
Mil1ion
Maybe read long with this thread ?
https://www.ford-trucks.com/forums/5...l-problem.html
Old Nov 19, 2006 | 10:02 PM
77MONEYPIT's Avatar
77MONEYPIT
Sounds like my problems ,alot of weird stuff happens because of a weak ground.Check all ground straps from plug sockets/battery to frame/block.Securely attached wires dont always mean good grounds.Old rusted frames and body bolts are good contributers to poor grounds. All my signals worked great until I turned on my head lights,added new grounds from battery to different body points .Problem solved.
Old Nov 20, 2006 | 12:42 AM
Ranger Gord's Avatar
Ranger Gord
...so the indicators come on and stay on? There's no *tick tick tick* noise? If there isn't, do what Bdox said, check the flasher unit. I'm pretty sure it's the same for the 79, but my 77 has 2 flasher units, one for hazards and one for signals. I couldn't figure out why I didn't have hazards for a long time. I switched the flasher units and presto, I found the problem. Just threw away the broken one and took a good one off of a parts truck.
