I have no experience with that cover. I'm good with my stock cover and the LFC drain plug.
By LFC drain plug, are you referring to the upgrade plug, part # 6E7Z-9C082-A ?
That's what I have. Little bugger is more expensive now than I recall.
$49 on Amazon. But it beats the original stock drain plug, especially on a 4x4.
Like Jack said, clean the turbo. If the truck has been sitting a long time, the unison ring is probably seized.
If changing the HPOP, also replace the J-tube, aka discharge tube
Other upgrades and/or longevity opportunities:
- 6.4 trans pan and filter
- harpoon fuel tank
- check driveshaft carrier bearing/bushing
- upgraded battery and ground cables
It ran great! Unlimited Diesel Performance gave it a light tune. More responsive than before. Sounds great. Easy start. Filled the tank and drove 312.3 miles. Filled the tank again with 15.3 gallons. That's 20.4 mpg. Kept the rpms just under 2000. Doing about 69-70 mph. Very happy. That was without cruise control. Unfortunately, the cruise control shuts off on any upgrade. It was fine on flat surfaces and downgrades. I suspect the brake pedal switch. What are your thoughts?
Sounds reasonable, check the pressure switch connector on master cylinder for presence of brake fluid too. If remember correctly that can be a thing on these years
- harpoon fuel tank
What is the reason for the 2008-2010 6.4 transmission filter and pan, as it relates to a 2003 6.0 F250?
The "filter" on our trucks is a coarse screen, whereas the 6.4 is a pleated filter that collects very fine particles. It is also a bit larger, which is why you have to replace the pan. It is considered a major upgrade and highly endorsed by our resident transmission specialist, Mark Kovalsky.
That can be left in place. The 6.4L doesn't have it; its in-pan filter replaces it. But if you want to do away with it, you have to do more work and replace the housing with tubing. IMO, I'm leaving it in place.
