code went away after fixing wiring and small things but this new code came. All airbag light codes also goes away when putting in a different ignition switch but then an ABS light turns on.
Is it a '52 Packard?
They use 2 digit codes
Code 12 is low battery voltage
The service manuals are your friends
So is a DVOM and a few pinpoint test steps from the service manual for the code
You obviously did not use the link to look at the other thread. If you did you would have learned the truck is a ‘95 F-150.
A ‘52 Packard had a computer that displayed 2 digit codes? Very advanced technology for then. I assumed it had points ignition and a carburetor.
