Air Bag Light Code
Old May 20, 2026 | 08:15 PM
charliedesh's Avatar
charliedesh
3rd Gear
Air Bag Light Code
Getting air bag light code 2-3. Any solutions?
Old May 20, 2026 | 08:43 PM
jas88's Avatar
jas88
Did you look up what that means? Could you share it perhaps?
Old May 20, 2026 | 08:51 PM
rla2005's Avatar
rla2005
Your other thread stated you were getting code 12
https://www.ford-trucks.com/forums/1...ight-code.html
Old May 20, 2026 | 08:53 PM
charliedesh
3rd Gear
code went away after fixing wiring and small things but this new code came. All airbag light codes also goes away when putting in a different ignition switch but then an ABS light turns on.
Old May 21, 2026 | 03:36 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Did you replace the part where you insert the key or the one on top of the column by the firewall?
Old May 21, 2026 | 08:29 AM
manicmechanic007's Avatar
manicmechanic007
Is it a '52 Packard?
They use 2 digit codes
Code 12 is low battery voltage
The service manuals are your friends
So is a DVOM and a few pinpoint test steps from the service manual for the code
Old May 21, 2026 | 11:48 AM
My4Fordtrucks
You obviously did not use the link to look at the other thread. If you did you would have learned the truck is a ‘95 F-150.
A ‘52 Packard had a computer that displayed 2 digit codes? Very advanced technology for then. I assumed it had points ignition and a carburetor.
Old May 21, 2026 | 11:57 AM
AuroraGirl's Avatar
AuroraGirl
1953 Ford Customline
Old May 21, 2026 | 11:58 AM
Scndsin's Avatar
Scndsin
OK, just to put my oar in the sh..., er, stew pot....
20 years ago I did a search about flashing AB light that led me here.
Don't know if it was 23 0r 32 but the fix was clock spring that was not made by aftermarket at the time.
Seems like no horn or cruise was present too.
YRMV
charliedesh
May 17, 2026 05:09 PM
shark1979
1983 - 2012 Ranger & B-Series
May 30, 2010 08:57 AM
RA81222
Jan 12, 2007 12:35 PM
mvlr5000
Aerostar
Nov 14, 2003 02:08 AM
