Air Bag light on
Old Jan 7, 2007 | 06:04 PM
RA81222's Avatar
RA81222
Air Bag light on
Air bag light comes on and blinks, then stays on steady.4x4 02' explorer 4.0L
Old Jan 7, 2007 | 06:30 PM
quicklook2's Avatar
quicklook2
it is sending you a code that it has failed it's check.
Old Jan 7, 2007 | 06:51 PM
bcjim's Avatar
bcjim
The blinking will indicate a fault code that repeats for a few times at startup. The code will point you to the culprit.
Old Jan 8, 2007 | 07:34 PM
RA81222's Avatar
RA81222
Codes Id
Where do I find the code info?
Old Jan 8, 2007 | 08:02 PM
quicklook2's Avatar
quicklook2
write down code and i will look it up in ford manual.
Old Jan 9, 2007 | 05:26 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Count how many times it flashes before staying on solid. That's your code.
Old Jan 11, 2007 | 05:31 PM
RA81222's Avatar
RA81222
thanks-I will get it when the wife gets back home.
Old Jan 11, 2007 | 07:26 PM
RA81222's Avatar
RA81222
code is 34 I believe-3 blinks then 4 blinks of the light.thanks
Old Jan 11, 2007 | 07:37 PM
MazdaRangerGuyInSTL
34 is "Restraint System - Safety Belt Pretensioner Status (Passenger Pretensioner Circuit Fault)"
First of all look at the wiring underneath the passenger seat, specifically the wires going to where the seat belt buckles... it's possible something underneath the seat knocked the connector loose or cut a wire.
If it all looks good disconnect the electrical connector and make sure the pins fit nice and tight, as these are VERY TOUCHY to any kind of electrical resistance at all. You might want to take a small screwdriver and push the female terminals together a little tighter... spray some electrical component cleaner in there and reconnect it. (NOTE - PERFORM THESE STEPS WITH THE BATTERY DISCONNECTED TO PREVENT ANY POSSIBILITY OF AIR BAG DEPLOYMENT... WHILE UNLIKELY IT IS A POSSIBILITY)
If that doesn't correct the problem about the only other thing you can really do on your own is replace the pretensioner (assembly the seat belt buckles into)... however these can be quite expensive... in this case it may be better to go to the dealer for diagnostics at this point... that is of course if the above step doesn't fix it.
Good luck!
Old Jan 11, 2007 | 09:05 PM
RA81222's Avatar
RA81222
thanks-I will check it out.
Old Jan 12, 2007 | 06:42 AM
bcjim's Avatar
bcjim
Safety restraint system has 5x60k warranty, unsure if this is considered part of that system, or if you are still under 5/60..
Old Jan 12, 2007 | 12:35 PM
piperRonnie's Avatar
piperRonnie
My 2002 Ex just started flashing 34. I looked at the alldata (free at my public library) and another possible cause is the clockspring in the steering wheel column.
