Headers for dent 4x4
Old May 9, 2026 | 06:15 PM
bfree01's Avatar
bfree01
6th Gear
OK guys I’ve got a 1979 F150 four-wheel-drive C6 automatic 205 case has a 302 and I need headers. the engine is built for mid-level performance. I don’t want to run a stock style Manifold. I’ve searched this site and the Internet and have not found a viable option. Someone has to have used a 347 or other 302 based engine in one of these trucks. I just can’t find any results that show what headers they may have used. I’m not opposed to a block hugger or a Shorty style. I just was hoping someone had actually made this swap and could give me reliable information on what would work.
Old May 9, 2026 | 07:28 PM
Greaser007's Avatar
Greaser007
I'm just guessing here, but a pair of Mustang block huggers might work depending on where they dump out on each side.
A good victor torch can make quick work of modifying the angle of the dump.
Ket us know what you find.
Old May 10, 2026 | 11:12 PM
motorsickle1130's Avatar
motorsickle1130
After rebuilding a set for a 76 to fit in a 78 with an FE, be smarter than me, and accept the compromise of shorties. If you can find a set of block hugger long tubes that route like shorties, I’d try that route.
Honestly seems like nowadays $500 is on the cheap end.
Maybe try something for a similar year mustang?
Old May 11, 2026 | 12:35 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Mad Dog has some fenderwell exit 302-351. https://maddogheaders.net/ford-headers
Careful Flashshark might be like Temu. https://flasharkracing.com/products/...0aAjInEALw_wcB
Summit Racing. https://www.summitracing.com/parts/s...MaAq-jEALw_wcB
2wd...https://www.ebay.com/itm/28723286630...caAldKEALw_wcB
Summit Racing big list, 2wd versus 4wd probably matters if you want long tube. https://www.summitracing.com/search/...0302%20headers
FTE talk about it. https://www.ford-trucks.com/forums/5...2-headers.html
Old May 11, 2026 | 12:42 AM
77&79F250's Avatar
77&79F250
Opps forgot Hedman Headers 1980-1996 2wd 4wd 302 https://www.hedman.com/product-detail/89350
Maybe they would work 1979---1980 what is a year difference?
Bricknose 250
Jun 19, 2023 11:22 AM
yomow
Feb 2, 2013 09:25 PM
hippyman01
Jan 29, 2006 09:19 AM
nixon_ca
Mar 29, 2004 08:08 PM
Franklin2
Mar 30, 2002 04:09 AM
