6.0 filter comparison
Old Apr 25, 2026 | 01:22 PM
Hartwig's Avatar
Hartwig
As you may know, Rockauto no longer ships many parts to Europe because they might contain Russian steel (no joke).
I can’t get filters, serpentine-belts, or anything else directly.
Lately, I’ve had the impression that the build quality of Motorcraft filters has declined
I’ve now transferred the FL2016 part number to a Donaldson filter and ordered this one here in Germany. In terms of dimensions, it’s identical to the Motorcraft filter, but it doesn’t have the hole in the middle like the FL2016; instead, there’s a movable part inserted there. It looks high-quality.
I won’t get the Donaldson fuel filter set until next month.
What do you think of the Donaldson filter?
I know it says “Made in China” on it. But we all know how many products are now manufactured exclusively in China. And if they really want to, they can make good products too.
Old Apr 25, 2026 | 03:03 PM
bismic's Avatar
bismic
I don't have anything against Donaldson filters in general. Just a bit sad that it has come to this, but not unexpected. Thanks for making us aware!
Old Apr 25, 2026 | 07:17 PM
joe blow's Avatar
joe blow
No disrespect intended, but I am really surprised you have not converted over to the air to oil cooler from BPD which gets rid of the OEM filter, OEM oil cooler and relocates the oil filter to the left bumper area.
Best thing I ever did to my truck and the filter is now a huge truck filter, and I use Baldwin exclusively.
Old Apr 26, 2026 | 05:52 AM
wpg_250's Avatar
wpg_250
The Motorcraft filters have been sub par for a while now. Think it was a year or two ago that I posted about the filters being covered in fuzz like shown in one of your pictures.
First thing I thought when I seen the fuzz was a plugged IPR. Funny enough, the FRAM filter I had just purchased was clean as a whistle fuzz wise and looked to be good quality and if it wasn't for that insert part piece I'd be running FRAM filters right now. I have 2 Motorcraft filters left and after that I'll be switching to something else.
Old Apr 26, 2026 | 06:45 AM
TooManyToys.'s Avatar
TooManyToys.
They have always had a little fuss. At around 9:07 minutes, you can see fuzz *****. This is a video I made a long time ago; my throwing the filter in the trash at the end was a joke.
Old Apr 26, 2026 | 09:17 AM
Hartwig's Avatar
Hartwig
I still have a small stock of filters; right now I have to buy them through third parties. I can't afford to be unable to work because I'm short on filters.
Jack: Why do you think the Donaldson filter has a “plug” in the middle?
I tested both versions by mounting them with my modified filter cap; I couldn’t tell the difference (new filter standpipe).
It has happened to me several times that the last few turns are harder to screw in; something in the filter standpipe is blocking it, and that was also the case with this Motorcraft filter. The Donaldson didn’t have this issue; it also has a different internal shape
Motorcraft:
Donaldson:
Old Apr 26, 2026 | 09:53 AM
TooManyToys.
It’s probably due to the difference in Donaldson’s filter production equipment. For the Donaldson setup, they may have needed a spindle to locate the cap or rotate on, which explains the hole and the need to plug it afterward.
Old Apr 26, 2026 | 10:01 AM
Hartwig's Avatar
Hartwig
The filter standpipe has a rounded pin in the center that seals the hole in the filter. That's why the extra part on the Donaldson seems unnecessary to me.
Old Apr 26, 2026 | 10:27 AM
TooManyToys.
Good point. I’m not a morning person.
Then are the heights of the filters the same? It seems they are blocking the hole for some reason.
Old Apr 26, 2026 | 11:11 AM
Hartwig's Avatar
Hartwig
Yes, Sir. Exact same height.
Old Apr 26, 2026 | 03:03 PM
TooManyToys.
I would try the filter with and without the plug and see how it fits on the standpipe, no cap. Just mimic if the cap was pushing down on the filter.
Old Apr 26, 2026 | 06:56 PM
Fuzzpuss's Avatar
Fuzzpuss
Got a problem with Fuzz, pal?
Old Apr 26, 2026 | 08:32 PM
wpg_250's Avatar
wpg_250
I knew you'd say something lol 😆
Lex2002
18
Mar 2, 2026 11:04 AM
acdii
6.7L Power Stroke Diesel
Nov 1, 2023 09:54 PM
82_F100_300Six
2004 - 2008 F150
Apr 18, 2022 04:47 PM
bdrummonds
44
May 4, 2010 04:55 PM
