5-6 shift flare, light throttle (2016)
Old Apr 23, 2026 | 10:44 AM
_Wulf's Avatar
_Wulf
searched and found plenty of shift flare threads out there, but most are for 3-4….
Under minimal throttle applications (rate of acceleration limited due to traffic), my 2016 flares the 5-6 shift for the first 1-3 shifts, then behaves normally. Under medium to full throttle it shifts perfectly. I have tried multiple KAM reset and fluid and filter changes with no luck. It actually gets worse after a KAM reset then clears up for the most part.
Dealer said “normal” but I hate it. Anyone run into this and actually fix it?
What are my next steps?
Custom transmission tuning?
Shift solenoid? entire valve body?
BD pressure enhancer?
Old Apr 23, 2026 | 12:03 PM
mini-x fan's Avatar
mini-x fan
My 2016 does this occasionally as well. I am just over 220k miles with the original fluid (to my knowledge). It has done this every once in awhile since I got the truck with under 100k miles. I just try to avoid light acceleration between 5-6 and get firm shifts that’s way.
Old May 1, 2026 | 10:53 AM
_Wulf's Avatar
_Wulf
Originally Posted by mini-x fan;[url=tel:21813759
21813759[/url]]My 2016 does this occasionally as well. I am just over 220k miles with the original fluid (to my knowledge). It has done this every once in awhile since I got the truck with under 100k miles. I just try to avoid light acceleration between 5-6 and get firm shifts that’s way.
I would be less bothered if it was occasionally, but it occurs every day I drive the truck
after it gets out a few funky shifts it runs fine the rest of the day.
Also, not sure if it is related to engine load or tow/haul mode but when I hook up the trailer and hit the road it doesn’t seem to do it
Matt Pace
6.7L Power Stroke Diesel
May 24, 2022 05:25 PM
Hiflyer746
Sep 26, 2009 03:58 PM
2 stroke man
32
Feb 7, 2008 09:12 PM
emmagator
Sep 15, 2007 03:16 PM
derherr65
Mar 16, 2006 10:00 PM
