motorcraft help
Old Dec 10, 2003 | 10:34 AM
hotbbb's Avatar
hotbbb
Thumbs up motorcraft help
i have a motorcraft2100 and this morning i was going to go to school but then i noticed that my car did not want to turn on. in the past it has always been my carb. the carb has been rebuilt a whuile ago and is running good . the problem is that it just needs tuning....... any replies would help. thx
Old Dec 10, 2003 | 11:20 AM
bubbaf250's Avatar
bubbaf250
I don't understand what you mean when you say the car didn't want to turn on.
Could you describe the problem in more detail?
Does the engine crank over with the starter?
Does it cough and sputter after the starter stops?
Can you get it running at all by moving the throttle?
Any history or other symptons you can describe?
Old Dec 10, 2003 | 12:12 PM
LxMan1's Avatar
LxMan1
Yeah Bubba, that's a tough one to diagnose!!!! My first off the wall, non informed guess would be that the temp dropped and the choke is too tight. But, I could be way off base. We will have to wait for more info.
Jimmy
Old Dec 10, 2003 | 01:02 PM
76390FE's Avatar
76390FE
It is very hard to tell whether the problem is fuel related or an electrical problem without knowing more details. But having problems this time of year would make sense that the choke is acting up.
Going to need to know more....
Old Dec 10, 2003 | 06:26 PM
hotbbb's Avatar
hotbbb
it turns over and sputters a litlle with me pushing the gas down it had electronic ignition . i am thinkinig that it is the choke because as soon as the day warms up it runs fine.
Old Dec 11, 2003 | 05:44 PM
bubbaf250's Avatar
bubbaf250
Sounds like the choke pull-down might need adjustment.
You can test the choke pull-down by applying a vacuum to see if the diaphragm holds vacuum. If it leaks, replace it.
You should adjust it to open the choke plate about 1/10" to 1/8" when vacuum is applied. The pull-down adjustment screw is on the back of the diaphragm chamber (2150 carbs) or on the bottom of the diaphragm chamber (2100 carbs).
1968grain600deere
Large Truck
Oct 21, 2020 05:03 PM
dgoodman
Jun 6, 2014 04:19 PM
8ITCOOL
Mar 16, 2004 07:07 PM
seans64'
15
Oct 16, 2003 10:46 AM
63SCtruck
Mar 10, 2000 07:25 PM
