Linkage Issue. Need some direction please.
Old Mar 19, 2026 | 10:14 AM
SC_Dave's Avatar
SC_Dave
First, I have not had a chance to look into this issue but I would appreciate some direction for when I have a look this weekend.
Had a no start issue. I pulled up on the gear shift and it cranked fine.
I then noticed the gear shift felt spongy when shifting to reverse and it actually did not go into reverse. Shifted to neutral then to reverse and it felt normal and actually went into revere as normal.
Thought about the neutral safety switch but that wouldn't explain the whole reverse thing.....
Your suggestion are appreciated.
David
Old Mar 19, 2026 | 10:33 AM
uglypitbull's Avatar
uglypitbull
Have you checked the little wheel under the dash....it adjusts the orange gear display on the dash.
Also, there are the 2 torx bolts that could be loose under the dash too.
Old Mar 19, 2026 | 10:38 AM
SC_Dave's Avatar
SC_Dave
I have not. But I will. I appreciate the suggestion!
David
Old Mar 19, 2026 | 10:50 AM
helifixer's Avatar
helifixer
There are 2 torx bolts at the end of the shift shaft under the dash that come loose. When they come loose the lever can't get the transmission seated in park and the range sensor won't close the start circuit.
Old Mar 19, 2026 | 10:57 AM
SC_Dave's Avatar
SC_Dave
Very good! I will start there. Thank you!
Old Mar 20, 2026 | 10:48 AM
Eman85's Avatar
Eman85
At the bottom of the column you will find the lever that moves the shift cable, the bolts come loose. They are torx bolts I think #25, remove ONE bolt and use blue Loctite on it then do the other bolt. It's also good to check the shift shaft bushings. The shaft runs down the top of the column and has saddles that hold it in place and plastic bushings that the shaft rides on. You can replace the bushings by just dropping the column. You have to be careful with the shift indicator cable and that plastic cable holder is probably cracked also.
Old Mar 20, 2026 | 10:53 AM
SC_Dave's Avatar
SC_Dave
Thanks much for the information!
Old Mar 21, 2026 | 10:45 AM
SC_Dave's Avatar
SC_Dave
Circling back. The torx bolts you guys referenced were in fact loose. Not much but loose enough. I tightened them and it appears to have fixed the issue. I'll know soon enough when I drive it. I did not drop the column and check the bushings that I saw referenced in a video I watched because I want to see if tightening the screw was the complete fix (I believe it is). I want to thank you guys once again for helping an old man out.
David
friesford
Nov 30, 2021 07:34 PM
birdboy
Mar 18, 2016 10:49 AM
farmb0y
Mar 12, 2008 01:05 PM
Soccer85
May 18, 2007 09:10 PM
Wakeboarder141
1978 - 1996 Big Bronco
Nov 3, 2004 09:14 PM
