Sponsored by: Real Truck
No reverse
Old Nov 29, 2021 | 07:48 PM
friesford's Avatar
friesford
No reverse
Hello everybody I have a problem with my 2003 Ford F-350 5.4L it has no reverse I have already put an other transmission under it I backed out of the garage then it stopped working I have no issue of driving forward it selects all forward gears but once I want back up it’s basically in neutral and it is not the selector because in park it does not move
and a other tcm
Old Nov 30, 2021 | 12:54 PM
Jakerichards1's Avatar
Jakerichards1
I Would certainly think you could not have the same trouble with two transmissions. I would start by verifying that the shift selector is actually picking the proper position for reverse and that the range selection switch that it goes through is in good working condition
if you have a second you can switch the two
Old Nov 30, 2021 | 01:21 PM
friesford's Avatar
friesford
One thing i tried today I put it in N then it drives forward and when I shift from park to reverse it moves little bit forward
Old Nov 30, 2021 | 07:34 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Either the linkage is adjusted wrong, or the forward clutch has failed and is welded together.
Frank79
Jun 18, 2021 05:40 PM
totalltom
Nov 26, 2017 11:38 PM
wevie
Feb 2, 2014 10:24 PM
gravel pit camper
2004 - 2008 F150
Oct 12, 2011 10:32 AM
Rockafella
Feb 15, 2003 09:09 PM
