Grinding in Reverse
Old May 18, 2007 | 06:17 PM
Soccer85's Avatar
Soccer85
Grinding in Reverse
I have a 1989 F-250 with a 5-speed transmission. I've been having trouble for a while with the reverse gear grinding every time I put it in gear. I've replaced the clutch and resurfaced the flywheel, but still 99% of the time it will grind when I try to shift into reverse. It works fine on all the other gears. It is even hard to shift into reverse with the engine off. Any input is appreciated.
Old May 18, 2007 | 09:10 PM
boggerted's Avatar
boggerted
If reverse is hard to shift in when the truck is off, it is possbile that maybe a linkage or a a shift fork is worn or broken.
