Power steering question.
Old Mar 10, 2026 | 07:33 PM
unibody62's Avatar
unibody62
After the snow melted and the roads had no more slip and slide, I noticed my PS not being as easy to operate. I removed the serpentine belt
to check everything. The tensioner has plenty of spring to it and most of idler pulleys seem fine. There is a little wiggle in the tensioner pulley bearing and the ribbed idler pulley bearing, so I’ll probably replace them. My big question is the pump, it doesn’t seem to have any resistance. Does that seem normal? How can I tell
if it working? I know that sucker is a bear to get a couple of bolts out, so I’m not really anxious to have to replace it. The belt doesn’t make any abnormal noise, but I’ll replace it also while I’m in there.
Old Mar 12, 2026 | 12:12 PM
HomerWinzlow's Avatar
HomerWinzlow
Maybe the pressure sensor is bad?
Old Mar 12, 2026 | 02:43 PM
unibody62's Avatar
unibody62
I wondered about that also, hopefully that would be easier to replace.
Old Mar 13, 2026 | 07:06 PM
90Ford73's Avatar
90Ford73
Spray the steering shaft ujoints generously with rust penetrant or chain lube or whatever is handy before crawling underneath the truck. Drive it around the yard and work the steering wheel, if it loosens up your shaft ujoints are running dry
Old Mar 13, 2026 | 07:33 PM
unibody62's Avatar
unibody62
Thanks for the suggestion, easy enough to try. I don’t really think it’s the problem because the truck has only 83k miles and is always garaged. However, I do live in the rust belt. There aren’t any creaky noises either. I was going to try and use a bidirectional scanner today to check PS pressure, but either my ECU isn’t equipped to give me readings or the scanner isn’t up to the task. Maybe both. I think I’m just going to replace the pressure sensor switch since it’s cheap and easy enough to get to.
Old Mar 13, 2026 | 08:49 PM
90Ford73's Avatar
90Ford73
Let us know if the switch fixes the issue
Old Mar 16, 2026 | 11:21 AM
unibody62's Avatar
unibody62
Well, turns out that the pressure switch was deleted from my model year. I even verified with the dealer so that leaves the pump or that rack. The mastery continues. It still works, just doesn’t act normal.
Old Mar 16, 2026 | 11:59 AM
HomerWinzlow
Sorry about that. I just checked mine, no pressure switch. Funny thing is when I checked the parts list at the online dealer it showed one for that year, included in the PS line. I have that line in my garage and sure enough, no switch on it either.
Old Mar 16, 2026 | 04:35 PM
90Ford73's Avatar
90Ford73
I wonder why Ford got rid of the pressure switch, just not needed? My 09 has, my 10 doesn’t.
You have to remember the age of the truck, the ujoints can just slowly dry up without any noise. Some report the shaft binding, others don’t. My brothers 06 had stiff steering and the pump was whining. I sprayed the shaft up and could feel it loosen up after about 4 turns of the wheel driving around the yard.
I am by no means saying it’s your problem for sure, but it’s easy to spray both ujoints up and go for a drive. Try it before spending time and money on anything else in the system.
I put a reman BBB rack in my 2010 because the steering was stiff, after a shaft replacement. It’s still stiff. Better but not how it should be. I also see Ford discontinued pumps and racks for these 09-10 trucks, that’s why I had to go aftermarket. I scored a used Ford low mileage rack but I think I still have warranty. I’m curious to see what your stiff steering cause turns out to be.
Old Mar 16, 2026 | 05:06 PM
HomerWinzlow
That reminds me, check the steering column intermediate shaft as well.... These were known issues as well.
Old Mar 16, 2026 | 05:30 PM
unibody62's Avatar
unibody62
I’ll definitely check into the shaft a little more thoroughly, although I sprayed with some penetrating spray this past weekend. I haven’t driven it yet on the street but it still acted different than normal. It’s not smooth, kind of uneven resistance is how I would describe it. I’m going to borrow a better bidirectional scanner from a buddy to see if the PCM will give me pressure readings before a spend any money. If the shaft is the problem, would it be best to replace it or just lube every so often?
Old Mar 16, 2026 | 05:59 PM
HomerWinzlow
If in doubt replace it, Ford replaced a bunch of them. Might even be a recall on them. I cant remember.
Old Mar 17, 2026 | 02:27 PM
90Ford73's Avatar
90Ford73
You can lube it just to get by until you replace it lol. My bro just kept his lubed every so often until he had time to change it.
It’s a pretty immediate difference after you lube them and work the wheel, if you didn’t notice any big change something else must be the issue
reggiedunlop
1983 - 2012 Ranger & B-Series
May 28, 2017 11:48 PM
gcpommom
Aerostar
Feb 17, 2011 10:25 PM
WALJON
Dec 30, 2007 02:40 PM
bob1987f
Oct 24, 2006 08:43 PM
mradster
General Automotive Discussion
Apr 23, 2004 09:35 AM
