The wire is black from the solenoid to the splice and black on the other side of the splice. The schematics I have show black/orange but I didn't see any orange.
I'm also not sure if the diagram I'm looking at is accurate to my truck. It doesn't show the red wire.
I haven't changed the alternator but I doubt it's original. I'll check in the morning.
Did you find a strange relay? Could it be the horn relay? They used a horn relay in 1980, but you might have some 1980 wiring if your build was close to the change over.
Thank you.
Looks like that was a splice in your first posts. If you are still missing a main fusible link, you can substitute a large mega fuse. I think the largest alternator offered on these trucks was a 70 amp. So a 90-100 amp mega fuse should do the job.
Jim was asking about it. I think it's either horn or marker lights.
