Firewall Plug
Old Feb 15, 2026 | 06:48 PM
86 f250 4.9l's Avatar
86 f250 4.9l
Trailering
Firewall Plug
Does anyone happen to have an extra firewall ecu harness grommet laying around? The part number should be something like E3DZ-14603-A I believe. I just finished an hei conversion on my 86 and I'm looking to clean up the engine bay. I can't seem to find one of these anywhere and it's getting harder and harder to find these trucks in the yards around me.
Old Feb 15, 2026 | 08:56 PM
JimsRebel's Avatar
JimsRebel
There's a version of this without a hole, used in non computer trucks. Is that what you are searching for? If so, that's a rare find.
Here's a photo of one. Someone poked some small holes in it.
Old Feb 15, 2026 | 09:43 PM
86 f250 4.9l
Trailering
Yup that's it, mine currently has the hole for the ecu wiring harness to pass thru but I'd like to keep my cab sealed after gutting the wiring
Old Feb 16, 2026 | 07:07 AM
Franklin2's Avatar
Franklin2
Definitely keep the cab sealed. Some gorilla tape, duct tape or something like that should do the job. Or take the old one with the hole in it, patch the hole with something and then put the old grommet back in.
Old Feb 16, 2026 | 08:22 AM
Staticbuster's Avatar
Staticbuster
Does this plug fit?
https://www.steelerubber.com/firewall-plug-20-0754-20
I forget if I got that part # from here or a facebook group, but I ordered some of those plugs. In my case I was replacing the plug in the firewall near the steering column. These worked and fit great.
Old Feb 16, 2026 | 09:26 AM
Max Capacity's Avatar
Max Capacity
HAve you tried to ask your local auto parts store. NAPA might have a catalog for those...
Old Feb 16, 2026 | 12:02 PM
86 f250 4.9l
Trailering
This look pretty close and the measurements are close enough. I'm gunna order one and give it a shot, thanks!
Old Feb 16, 2026 | 07:42 PM
Staticbuster
Hope it works for you, glad I could finally be a helper on this board. I've gotten so much help it feels good to finally pay it back, if even in a small way!
Old Feb 23, 2026 | 02:46 PM
James Heathcoat's Avatar
James Heathcoat
Trailering
I'm needing the same grommet for my computer delete that I did. What's the info I need to get one??
I need the same thing for my computer delete. What's the info I need to get my hands on one???
Old Feb 23, 2026 | 06:57 PM
FuzzFace2's Avatar
FuzzFace2
Look at post #5 for a link to one that may work.
Dave ----
Old Feb 23, 2026 | 07:00 PM
2000duallydiesel's Avatar
2000duallydiesel
Glad I stumbled across this. I forgot all about Steele Rubber website. I have a spot on my firewall i'd like to upgrade from cardboard and tape to an actual plug.
Old Mar 2, 2026 | 01:05 PM
James Heathcoat
Trailering
Solid firewall plug to seal up the ecm wiring that I deleted.
I also need a solid grommet to replace the ecm wiring that I deleted.
Old Mar 2, 2026 | 08:37 PM
BigBlue2's Avatar
BigBlue2
If you can't find one you could make yourself one. Rolls of 1/8" thick neoprene of various widths are available for about a buck a foot. Cut three pieces. One exactly the size of the opening. Contact cement a second piece that's about an 1/8" larger around centered on the sized piece. Cut a third piece that's oversized by an 1/8" or even more say a 1/4" larger on the side you want more secure. Contact cement the three pieces together and then you have a custom sized to fit grommet.
monkey-1
13
Mar 2, 2026 10:54 PM
redbayredneck
Oct 21, 2020 02:38 PM
86 300ci
Dec 16, 2017 05:49 PM
zspeed130
Feb 25, 2014 08:15 AM
rustfixer
Dec 24, 2010 06:48 AM
