Hood Bulge Alignment Issues
Old Feb 27, 2026 | 11:18 PM
TAMAOSO's Avatar
TAMAOSO
1st Gear
Having issues trying to figure out how to diagnose the “bulging” issue. Loosened hinges and moved around to different placements, still no luck. Any help will help.
File Type: mov
Old Feb 28, 2026 | 05:02 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
You need to take the hood off and bend it back flat or get another hood. You're more than likely going to need to just replace it.
Since this isn't engine related, the best place for this question is here:
Old Feb 28, 2026 | 06:43 AM
97-psd's Avatar
97-psd
The hood itself is bent. You won’t be able to make it align correctly without straightening it or replacing it. I would also consider replacing the hinges/springs as they are rusted/damaged causing the extra force which caused the bend initially.
Old Mar 1, 2026 | 12:08 PM
defdes's Avatar
defdes
I had a hood "blow up" on my Datsun 510, though the hood is smaller and lighter gauge, I was able to straighten it manually. For a hood like this I would remove the hood, make a Masonite template of the fender body line and get it close, an extra set of hands and their counter weight would be helpful.
Old Mar 1, 2026 | 05:13 PM
tjc transport's Avatar
tjc transport
i ain't rite
i only had limited success fixing hoods like that. i would put a 4X4 up at the rad support, and a 2X4 along the cowl and press down on the bulge. for work trucks it would be good enough.
but for nice trucks the only thing that really worked was replacing the hood.
riderboy1961
Jun 2, 2024 12:17 PM
Weatherwalk
Jun 25, 2023 09:49 PM
shiny
May 24, 2021 08:52 AM
Justforfishing
Sep 22, 2019 08:13 AM
vincel1965
21
Apr 8, 2013 02:31 AM
