Slick hood alignment issues
Old May 23, 2021 | 02:23 PM
shiny's Avatar
shiny
7th Gear
Hows it going? I am having grief with my hood sticking up on the right side of my Merc about half an inch. Even took it off yesterday and oblonged the holes and trimmed the bottom a bit, made it a little better but still sticks up. Is it that the spring has lost some tension? The truck I took them off of was aligned fine. Any ideas appreciated! Cheers! -Shiny
Old May 23, 2021 | 09:12 PM
AZ66F100's Avatar
AZ66F100
A bad hinge can cause that. I need to get a new one for mine. My DS hinge bound up one day and despite
working with it a lot, it just won't quite go back to the right position when closed.
Old May 24, 2021 | 04:17 AM
Crop Duster's Avatar
Crop Duster
That is a common problem with old worn hinges. Those hinges are reproduced. I have heard mixed results from members who have used them, but they are supposed to be the same as the originals.
Search: 6 results found for "Hood hinge" – Carolina Classics F100 (carolina-classics.com)
But if your hinge is close to fitting you can add a washer or two under the front bolt between the hinge and hood and it will bring it down in the back. I'm too cheap to spend $85+ on a new one so I did the washer trick on my drivers side.
Old May 24, 2021 | 08:50 AM
jjriley97's Avatar
jjriley97
Mine are much worse than yours, but this works like a charm. I used body shims in mine and was able to bring it down about 5/8 of an inch.
Old May 24, 2021 | 08:52 AM
James_Western_Canada's Avatar
SHINY!!! WTH have you been?? lol Good to see things on the island are still moving, even with the worldwide conditions.
Cheers!
James in Edmonton
oldracerjones
Aug 20, 2020 08:58 PM
Another rusty Ford
May 19, 2020 08:28 AM
fajitamondays
Feb 2, 2019 07:53 AM
thepitshop
24
Sep 22, 2016 07:56 PM
vincel1965
21
Apr 8, 2013 02:31 AM
