1978 - 1996 Big Bronco
Power steering problems
Old Feb 25, 2026 | 06:19 AM
Bigjim88's Avatar
Bigjim88
4th Gear
I'm having problems with my power steering foaming over, I've replaced the power steering pump and the power steering gear and I have a new high pressure line can't seem to get it to work, no matter what I do, I've done 20 times lock to lock, I've turned it. Over to take the air out without it running. But as soon as I started, it foams up and flows over with no power. In the steering can anybody help me?I'm lost
Old Feb 25, 2026 | 07:08 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Lock to lock with the engine off and the wheels on the air until the level no longer drops. Then you start the engine and cycle the wheel back and forth immediately shutting off the engine if the pump starts to run dry. Is this what you are doing or something close to this? When you start the engine you are getting a lot of air in the system?
Old Feb 25, 2026 | 07:12 PM
stephen.osborne1's Avatar
stephen.osborne1
Ditch the stock pump. Look into a Saginaw swap. No more whining. Better pressure. Bleeds easy.
Old Feb 26, 2026 | 12:31 AM
My4Fordtrucks
Never had any problem bleeding the Ford C2 pump. Pump noise varies - one can be totally quiet and the next you can hear three blocks away.
Old Feb 26, 2026 | 07:09 AM
Bigjim88's Avatar
Bigjim88
4th Gear
Thanks for in put it sounds like I'm just not having enough patience I also am going to ditch the dax/merc and try typeF I'll try again this weekend
Old Feb 26, 2026 | 08:02 AM
My4Fordtrucks
Type F is what Ford used but that isn’t causing an aeration problem. If I remember correctly, Type F doesn’t have as many additives for transmission clutches and seals
Old Feb 26, 2026 | 08:45 AM
KULTULZ's Avatar
KULTULZ
https://tpautorepair.net/what-causes...the-reservoir/
There is also a vacuum tool for hard cases.
Old Mar 4, 2026 | 11:40 AM
My4Fordtrucks
Better? Worse? No change?
Old Mar 4, 2026 | 07:37 PM
KULTULZ's Avatar
KULTULZ
It sounds like you have an air ingestion problem on the suction side of the pump/
If a rebuilt pump, what fluid type did the instructions call for?
Any chance of posting what it is you are working on?
Old Mar 6, 2026 | 09:28 AM
Bigjim88's Avatar
Bigjim88
4th Gear
Dexter/merc is what I used I'm switching it to typef everything but the return line is new it 2nd pump When I\n Crank it over with the coil wire disconnected, it sucks the fluid down and I refill it, then when I start it, it sucks it down until it vanishes in air bubbles appear overflows.
it's a 79 bronco
Old Mar 6, 2026 | 10:54 AM
My4Fordtrucks
it's a 79 bronco
Why are you cranking the engine? Have you done this part….
Bigjim88
Feb 26, 2026 08:03 AM
DerekP
Aug 1, 2021 03:20 PM
squash04
Nov 22, 2009 01:14 PM
