power steering problems
Old Nov 21, 2009 | 06:42 PM
squash04's Avatar
squash04
i have a 74 ford f100 4x4. i just put power steering in it. i bought a new pump and gear box and lines. i spend over 600.00 on the hole power steering. i put in it and it works for about 5mins and then i have no power steering. i changed out pumps and still nothing. i changed gear boxs and nothing. i checks the lines and there not pluged. any ideas on what i should do now???? please help...
Old Nov 21, 2009 | 07:00 PM
hp246's Avatar
hp246
Did you purge the air out of the lines after you put everything together? Put the front end on jackstands. Engine running, in park or out of gear, parking brake on. turn steering lock to lock continuously for a few minutes. You may have to add PS fluid.
Old Nov 21, 2009 | 08:38 PM
squash04's Avatar
squash04
i tryed that and it works for about 5mins and then i loss power steering. i replaced 8 pumps and 3 gear boxs and all are new.
Old Nov 21, 2009 | 09:59 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
It can take A LONG time to purge the air out of the system.
Josh
Old Nov 21, 2009 | 10:05 PM
hp246's Avatar
hp246
I agree with Bullet. I actually had to drive mine 2-4 times before I worked all to fhe air out of mine. At one point the pressure built up enough that it actually blew the dipstick out of the pump because Corrosion had built up to seal the top of the old dip stick. Works great now.
Old Nov 21, 2009 | 10:21 PM
Bullitt390's Avatar
Bullitt390
You just have to stay with it. I rebuilt my p/s pump, drained all the lines, installed a new cooler, etc... filled the system, had pressure, turned it lock-2-lock, a couple dozen times, topped it off and thought I was good to go.
Drove it the next day, 15 miles one way, drove 13 miles back and the p/s went manual. Drove home, turned it lock-2-lock a few times, topped it off and haven't looked back.
Josh
Old Nov 22, 2009 | 01:14 PM
squash04's Avatar
squash04
thank you for the help. i will try that.
